Old Sep 20, 2006, 06:23 PM
Joined Aug 2006
How to tile a plan in PDF ?
Can somebody tell me how to tile a plan in PDF in order to print it out ?
I have a plan here but is in full view. It wont print the entire plan.
I attached the plan here in order to have some ideas on how I can do to print it out or tile this plan (better yet).
Thank you
Marcelo-Skyfly is offline Find More Posts by Marcelo-Skyfly
Old Sep 20, 2006, 08:37 PM
Spring time, planes bloom
ecologito's Avatar
near UNC Charlotte, NC
Joined May 2003
to get a full plan to tile you need adobe acrobat pro.
Here is the plan you posted tiled. Good luck
ecologito is offline Find More Posts by ecologito
Old Sep 20, 2006, 08:47 PM
Joined Aug 2006
Thank you very much for the info and thank you for "tileing" the plans ..!!!!
Old Sep 21, 2006, 06:48 AM
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
The best way I know of to tile plans is to ask Gene Bond very nicely Some of the other guys in here also will do this for you if you ask nicely.
I usually do a bunch of computer gymnastics instead. I will print out a dxf/dwg/pdf file on a single pice of 8 1/2 x 11 paper. Then I scan it using the best resolution I can without crashing my 'pter . Then the scan gets cropped to make the various parts as small as possible. Finally, I open those pix with Tileprint, and print them in the size I want. I got a beta version of Tileprint for free - nowadays you can get an evaluation copy for free. The full-blown program is cheap and works well.
http://www.blackflight.com/planes.asp?plane=tileprint
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Sep 21, 2006, 07:34 AM
jimsp's Avatar
Sayre,PA
Joined Sep 2002
Most drawing and CAD programs will allow you to print out on overlapping pages. If you create or can get the drawing into the program you can use a program like deskPDF Writer (www.docudesk.com) to create an overlapping PDF file. The way it works is you print to deskPDF which is a print driver. It in turn creates the PDF file. Here is an example of a float drawing I made using VISIO. I put the scales on to help with aligning the sheets. The free trial version leaves the watermark on but I donít see that as a problem.
jimsp is offline Find More Posts by jimsp
Old Sep 21, 2006, 08:31 AM
www.ricoj.rchomepage.com
RicoJ's Avatar
Nieuwegein/ Netherlands
Joined Feb 2004
maybe a bit overdone but:
- From CAD or whatever print to pdf 1:1 (model scale)
- Open it in photoshop and copy
- I have a photoshop document that has lines and slices in it that are smaller than A4 and letter, paste it there
- Adjust so that not all the parts are cut in halfs and quarters
- Save for web... will save all slices as images
- Batch the images to a pdf file
A long way but the advantage is that you can readjust the parts so they fit nicely onto the pages.
RicoJ is offline Find More Posts by RicoJ
Old Sep 21, 2006, 08:49 AM
I do it the way jimsp does. I found a free PDF print driver that seems to work well. Just search for PrimoPDF in Google.
adamdb is online now Find More Posts by adamdb
Old Sep 24, 2006, 10:04 AM
ecologito's Avatar
Joined May 2003
All I do is open the full sheet pdf file with Acrobat Pro and then pint it into multiple pages, it is a 1 simple step and you can apply some overlapping if you need. This is only allowed on the Acrobat Pro version.
Old Sep 24, 2006, 10:49 AM
jimsp's Avatar
Sayre,PA
Joined Sep 2002
Unfortunately Acrobat Pro cost around $400 so it's really not an option for most of us. However you can download a free 30 day trial of the program so you can tile plans you may have on hand.
Old Sep 25, 2006, 05:04 AM
Just one more.......
Sim69's Avatar
Brisbane, Australia
Joined Nov 2005
An excellent and cheap program that I use all the time is tile print. Highly recommended.
http://www.blackflight.com/tileprint/
oops, should have read all the previous posts
Sim69 is offline Find More Posts by Sim69
How to publish a plan in a magazine ? LoopingFred Scale Kit/Scratch Built 17 Nov 23, 2005 12:58 PM
Question How would you go about putting plans in a PDF format? Mat Electric Plane Talk 6 Aug 11, 2004 02:06 PM
How do I print a large PDF in tiles? iam Foamies (Kits) 2 Mar 25, 2004 04:09 PM
Does any one know how to tile a plan in adobe? Funflier1 The Builders Workshop 5 Feb 01, 2004 04:07 AM
How to tile a PDF? Tram Electric Plane Talk 0 Nov 20, 2003 05:45 PM
