Old Jul 17, 2005, 09:16 PM
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
OS Max 30 -S engine
I assume OS doesn't make the 30 MAX -S anymore. I just picked one up to use in an old MEN Trainer. The trainer calls for a .15 to .25 engine. It has a 58 inch wing span and the wing is of an undercamber design. Supposedly, the plane weighs about 3.5 pounds. I still have to cover it yet and add servos etc. Anyways, anyone know about this engine? I am going to have to find a muffler for it too.
Dave...
LuckyArmpit is offline Find More Posts by LuckyArmpit
Old Jul 18, 2005, 08:39 AM
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
They're a very good older engine but be warned, it uses an iron piston and absolutely needs at least 25% all castor in the fuel. The weak point in these engines actually is the big end of the conrod. With less than 25% all castor the bush wears out quite fast (actually from memory the rod isn't bushed but runs plain aluminium). Also they're a bushed crankshaft and neither of my Max-S 35's have a steel shim behind the thrust washer so either hand start it or be very gentle with an electric starter.
downunder is offline Find More Posts by downunder
Old Jul 23, 2005, 11:51 PM
United States, SC, Irmo
Joined Jul 2004
I've got two of those 30s. Easy starting, pretty reliable, but less power than my Fox 25s. They would probably be adequate for that MEN trainer. Just remember they are lapped iron pistons and definitely need losts of CASTOR. This type of engine can overheat and wear out the liner/piston area FAST.
50+AirYears is offline Find More Posts by 50+AirYears
Discussion Noob needs help w/ engine ID on OS MAX .61's Kilroy_ Engines 18 Jan 04, 2007 07:44 AM
Off Site O.S. Max 30 Glow Engine w/Muffler - Excl. Cond. Mini Buzzard Aircraft - Fuel - Airplanes (FS/W) 2 Jun 28, 2005 08:48 AM
2 OS MAX .20's - FREE SHIP punkindrublik Aircraft - Fuel - Airplanes (FS/W) 0 Apr 01, 2005 12:28 PM
OS MAX 65 df engine complete gaucho Aircraft - Fuel - Airplanes (FS/W) 0 Mar 14, 2005 07:57 AM
FS: OS max 32F ABC engine eliu Aircraft - Fuel - Airplanes (FS/W) 5 Mar 08, 2005 12:38 PM
