Old Jul 26, 2014, 09:24 AM
SubaruMike's Avatar
United States, DE, Magnolia
Joined Nov 2011
Goop instead of Welders?
Hello everyone!
The kit i'm building calls for the use of Welders adhesive and it is not locally available (to my knowledge). However I do have Goop. Can I use Goop instead? I have heard they are basically the same thing, but I have no idea. Thank you for your time!
SubaruMike is offline Find More Posts by SubaruMike
Old Jul 26, 2014, 11:35 AM
Lilienthal's Avatar
Littleton, CO
Joined Nov 2010
Use Welders or Foam Tac. Goop is not the same thing.
BTW, someone here reported finding Welders at AutoZone recently. Some have reported finding Welders at Lowes, but I've never had any luck with them. Typically, I just buy on-line.
Lilienthal is online now Find More Posts by Lilienthal
Old Jul 26, 2014, 11:52 AM
ProBro Spaz
spastic's Avatar
Buffalo, NY
Joined Aug 2004
go to walmart and get QuickGrip, IMO and others it beats Welders, QG never yellows like welders does and dries faster, and is less rubbery, but still flexible
spastic is online now Find More Posts by spastic
Old Jul 26, 2014, 02:14 PM
Sam Adams Fan
DG40's Avatar
USA, PA, Honesdale
Joined May 2008
Used goop on lots of EPP models and works great. Stays flexable, doesn't yellow or get brittle over time like welders. It takes longer to setup but worth it to me.
DG40 is offline Find More Posts by DG40
Old Jul 26, 2014, 03:12 PM
Christian F
United States, CA, Redwood City
Joined Mar 2011
I have had great luck with Hotglue on my EPP planes also.
CaliPilot is offline Find More Posts by CaliPilot
Old Jul 26, 2014, 03:39 PM
SubaruMike's Avatar
Joined Nov 2011
Thank you everyone for your suggestions! I went to Lowes and AutoZone and still no Welders. SI went ahead and picked some QuickGrip. Thanks for the suggestion Spastic
Old Jul 27, 2014, 09:28 PM
Ground Pounder
Gharddog03's Avatar
United States, CA, Fresno
Joined Nov 2012
Quick grip works great!!
Gharddog03 is offline Find More Posts by Gharddog03
Old Jul 29, 2014, 12:00 PM
United States, OR, Happy Valley
Joined Aug 2012
Goop is strong but a much slower cure and it runs if you use much. E6000 is the same but you can get it in a tube with a small nozzle.
fooferdoggie is online now Find More Posts by fooferdoggie
Old Jul 29, 2014, 01:02 PM
dynodude's Avatar
El Cajon, CA
Joined May 2007
I know that everyone has their opinion on what is best. For me, I use Goop on all of my EPP builds. It never yellows, or gets brittle like Welder, and is super strong. I put a thin layer on all the stress and break points of my foamies and it is like body armor. No matter how bad the crash the plane won't break where there is Goop. The only thing about it is you have to work fast with it because it will "skin over" fairly quick.
dynodude is offline Find More Posts by dynodude
Old Jul 29, 2014, 08:29 PM
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
I use Household Goop on all of my EPP planes. But it will eat right through Depron.
rmgmag is offline Find More Posts by rmgmag
Old Aug 04, 2014, 09:05 PM
Registered RC NUT!
The Snake's Avatar
United States, CA, Lomita
Joined Jun 2002
Tack with foam safe CA, the fill with Goop or hotglue for me too. Goop is nice for those areas that flex is needed and hotglue where I wish it to be more stiff.
The Snake is offline Find More Posts by The Snake
Old Aug 04, 2014, 11:48 PM
United States, CA, Heber
Joined Sep 2012
I put together my first EPP. I used E6000 for spar and all else I used my wife's mini hot glue gun. I don't see to many people giving thumbs up for hot glue, but maybe someone with more experience will tell me why. The plus side, to me was it set up fast and it flexible.
jk6672 is online now Find More Posts by jk6672
Old Aug 05, 2014, 12:03 AM
Registered RC NUT!
The Snake's Avatar
Joined Jun 2002
it wasn't for portable hot glue gun would have threw away my way my planes along time ago!
Old Aug 05, 2014, 01:05 AM
Christian F
Joined Mar 2011
Ive been using hot glue on all my build, the only issue ive run into is that the motor mounts get loose when the motor heats up, so those i use epoxy, and that the rest of if gets soft in hot air either outside or in my car, but its not catastrophic.
Old Aug 05, 2014, 08:45 AM
ProBro Spaz
spastic's Avatar
Buffalo, NY
Joined Aug 2004
hot glue is heavy, i like it for servo install because with a dab of alcohol it releases .. for field repair quick grip is fast enough, with the sun out it's very fast, 5min or so..
motor mounts should have some tape to help out, standard practice look close you can see the tape
Discussion Goop works the same as welder glue on epp? jackheli Foamies (Kits) 8 Dec 29, 2013 10:00 PM
Idea liquid latex instead of goop flybaby2000 Slope 11 May 22, 2006 06:16 AM
New Product Household Welder same as GOOP. KingOfTheHill Slope 9 Feb 14, 2006 11:54 PM
Thinned goop instead of 3M spray for covering. DennisRB Slope 7 Jul 01, 2005 11:50 AM
