Old Apr 17, 2014, 04:55 PM
Joined Sep 2013
Servo ideas
Hi, I have a small project where I would like to control the pan and tilt of a camera. Basically I would want the camera to rotate at every 60 degrees, 6 times then the camera would tilt to new angle and then rotate again 6 times every 60 degrees and finally tilt again and stop.
So far I have seen that this is pretty much all possible using the Pololu Maestro Servo Controller and software to program it.
http://www.pololu.com/product/1352
The main problem I have is finding the right servo that I can use to move at 60 degree intervals through a full 360 degrees. It seems that some servos only do 180 deg. I am pretty new to all this stuff and trying to avoid costlt mistakes.
Any help appreciated.
nerjavirtualtour is offline Find More Posts by nerjavirtualtour
Old Apr 17, 2014, 09:46 PM
Condescending Pedant
Joined Aug 2013
Do some research on gimbal motors. They are designed from the ground up to position cameras. They may be more expensive than servos, but they will get the job done very easily, I believe. I have no firsthand experience with them.
Mike Dubovsky is offline Find More Posts by Mike Dubovsky
Old Apr 18, 2014, 02:25 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
The Netherlands, GE, Nijmegen
Joined Feb 2001
->search the DIY electronics subforum!
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Apr 18, 2014, 02:35 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Also see if any of these mechanisms would help --
Hobby King Camera Gimbals
also
Hobby King Gimbal Controllers
and
Hobby King Pan and Tilt Units
eflightray is offline Find More Posts by eflightray
Old Apr 18, 2014, 03:18 PM
Morristown,NJ
Joined Oct 2003
sail winch servo:
http://www.hobbyking.com/hobbyking/s...40kg_150g.html
moyg is offline Find More Posts by moyg
Discussion Elevator to flap mixing: dumb idea or good idea??? (see video) rudyauction509 Electric Plane Talk 20 Nov 16, 2013 07:24 PM
Wanted Receiver, Servos setup? Will entertain offers/Ideas! Tommy D Aircraft - Electric - Airplanes (FS/W) 1 Apr 21, 2004 10:22 PM
Need some ideas about servos AUBrian Hand Launch 3 Sep 24, 2002 12:22 AM
