Old Jan 27, 2014, 07:19 PM
Mfg of the Marauder & Oculus!
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
Oculus EXL
Did some testing on the new stabs for the Oculus EXL this Sunday. The new larger stabs look great and preformed wonderfully. It made a big difference in the way the airplane handled in slow tight turns. The stall recovery was also faster. Even when it was flying in light lift you could see it wanted to float like a feather in the lift. Hope to have the wing on the board real soon in the next few weeks.
I am starting to see why I fly this airplane and why I love this hobby so much.
Merrill
Mr B.... is offline Find More Posts by Mr B....
Latest blog entry: Oculus EXL
Old Feb 08, 2014, 02:27 PM
NZ7C's Avatar
United States, AZ, Gilbert
Joined Jun 2011
Merrill -
Will you be selling separate wing kits once the new model is out for those who may wish to upgrade an older ALES wing?
NZ7C is offline Find More Posts by NZ7C
Old Feb 08, 2014, 02:56 PM
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
Like I have stated before in other post the new wings will not fit the old wings. The spar ID size is larger. It went from .350 to .405 Sorry the supplier stopped carrying the parts. It was a good thing to go to the larger wing joiner anyway. It was time to make it better for all. Sorry that they will not be enter changeable. The fuse will be new as well. I am making a few changes to it. The rudder fin will have a filet for the LE of the elevator soon. Hope to have a new mold by May.
Merrill
Old Feb 08, 2014, 03:57 PM
NZ7C's Avatar
Joined Jun 2011
deleted
Old Feb 08, 2014, 04:36 PM
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
Originally Posted by NZ7C View Post
Actually, I meant the ENTIRE wing, but sounds like it won't match to the original fuselage as well.
I never said that it wouldn't fit the fuse!
Merrill
Old Feb 08, 2014, 05:30 PM
NZ7C's Avatar
Joined Jun 2011
deleted
Old Feb 27, 2014, 11:37 PM
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
E-Oculus EXL
Here is a look at the new 48" center wing panel for the EXL. After hours of designing, proto type and building a wing here it is!
Merrill
Old Feb 28, 2014, 12:30 AM
Build/Fly/Crash/Repeat
United States, HI, Kapalua
Joined Jan 2002
Very cool.....
CoastalFlyer is offline Find More Posts by CoastalFlyer
Old Feb 28, 2014, 01:20 AM
Gasbags & Gussets
jswain's Avatar
Riverside, Ca
Joined Feb 2009
thanks for update
Merrill
Nice photos showing a lot of detail how it will assemble and work, glad its going well.
js
jswain is online now Find More Posts by jswain
Old Mar 01, 2014, 02:08 PM
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
Video
Here is a short video I made in the shop the other night.
Merrill
E-Oculus EXL (1 min 43 sec)
Old Mar 14, 2014, 09:36 PM
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
Here is a photo I took of a mod for the flaps. I had a little to much flex happening with just the gussets. It's coming along nicely and should have it done soon.
Merrill
Old Jun 28, 2014, 09:58 PM
United States, NY, Hamburg
Joined Aug 2011
Finally cut the nose off the oculus and installed a motor. It wasn't physically hard, just mentally hard wack off the tip of that nice fuse. After a few hand tosses and trim changes, I gave it a good heave and fired up the motor. Climb was awesome and easily controllable. There will be no problem using this set up for ALES.
HYPERION Gs3020-8
Hacker 70 amp BEC
16/8 aeronaut CAM prop
2200 3s lipo(moto calc reccommended 2200 2c) I needed the weight to ballance so I
used the 3s
I did not put any servos in the tail, both R&E under the wing saddle.
Final weight 75, I am guessing the extra servos, wire in the wing added a few ounces.
Full run up was 64 amps and 590 watts. I only used about 80% throttle to fly.
I orgionally had spoilers in the wings and added flaps, so I now have a RESF.
The flying was the same as before the motor, awesome.
tailsld is online now Find More Posts by tailsld
Build Log Oculus RES Build onethermal Thermal 1172 Jul 10, 2014 01:04 AM
Discussion Good kit mfgs, dying breed? (non-ARF) UPDATE: active mfgs. listed! Wacky1 The Builders Workshop 26 Apr 27, 2012 02:42 PM
Rant A mistake buying from CENTURY JET MFG!! Kmot Fuel Warbirds 23 Oct 11, 2007 04:03 PM
Question Search plan : Tri-Star from SIG mfg Zappi Electric Plane Talk 7 Apr 10, 2005 01:01 PM
TP2100 pack ruptured from MFG Darren Hintze Batteries and Chargers 2 Mar 29, 2004 10:58 AM
