Old Jun 01, 2012, 01:24 PM
Canada, QC, Sainte-Julie
Joined May 2003
1/4" pine dowel for wing spar - strong enough?
Hey guys,
Help a newbie scratch builder!
I have only 1 carbon spar left (.021) but have a bunch of 1/4" pine dowels - weight is exactly the same as carbon for a 48" length although the dowel is slightly more flexible.
Do you guys think a pine dowel would be strong enough to be used as a wing spar?
The project is a 50" ws Cessna 172 trainer using a Kfm2 airfoil.
AUW should be around 10 to 12 oz by the way - and the plan is to NOT use this for any kind of aerobatics.
Thanks !
Fred
Fred Methot is offline Find More Posts by Fred Methot
Old Jun 01, 2012, 01:56 PM
12th Pursuit Squadron
TheAeronut's Avatar
Garland, Tx.
Joined Mar 2002
I have considered doing almost the same thing - wood dowel in KFm airfoil and about 48" span. At 10-12 oz I think it would be OK for sport flying with not much more than a gentle loop. If you were to use functional wing struts then the wood spar would be more than enough. My project development led me to drop the spar altogether. I will be using a foam 'spar' as a shear web/spreader to get the wing thickness that I want and use functional wing struts to carry the load. The wing will now be two piece with 24" panels attached to either side of the cabin. This project should hit the building board in the next couple of weeks. I hope to present it on this forum in the not too distant future.
J.P.
TheAeronut is offline Find More Posts by TheAeronut
Old Jun 01, 2012, 01:59 PM
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
I think I'd be worried about pine. It does tend to be bendy. Can you find some bass wood dowels?
What type foam are you using?
You could always use two 3/16 inch dowels and glue them together. I don't think I'd trust the pine alone though.
dedStik is offline Find More Posts by dedStik
Latest blog entry: More Confessions of a Smoker
Old Jun 01, 2012, 02:01 PM
Joined May 2003
You're absolutely right - I retested the "rigidity" of both spars and the pine one I can make quite a large arc with it - I thought once epoxied to the wing it would be quite stiff though.
Foam - I'm using dollar store foamboard (3/16" without paper) - both sides with peeled off paper - not the stiffiest material I agree...
Old Jun 01, 2012, 03:15 PM
dedStik's Avatar
Joined Feb 2012
When sammiching a spar I won't use epoxy on it. I've only used epoxy on spars that are exposed. Epoxy will work great, but it adheres to the spar and gives it some rigidity. I found this out the hard way, crashed a small 3D plane I built last week. I was mad about having to buy another cf spar, till I realized it was only encased in the epoxy. Two sets of pliers one either hand and twisting opposite directions the epoxy gave and I could slide the spar from the epoxy like a straw. I have since put it in the rebuild.
Spruce is always a good spar choice, nice hard wood. Bass wood works too if you can't find spruce.
Old Jun 02, 2012, 07:54 AM
AKA Don
bz1mcr's Avatar
United States, MI, Houghton Lake
Joined Dec 2002
In my experience 1/4 dowel is not good for planes with a span more then 30-36".
For a 50" aerobatic plane with a KFm2 I would want at least a 1/2" dowel.
bz1mcr is offline Find More Posts by bz1mcr
Old Jun 02, 2012, 09:06 AM
Joined Jul 2005
Pine Spar
1/4" pine spar should be adequate for your use. The spar, coupled with the KFm doubler should hold up OK.
oct2633 is offline Find More Posts by oct2633
Old Jun 02, 2012, 03:06 PM
Blacksburg, VA 24060 USA
Joined Feb 2000
1/4" pine dowel should work fine. Also add another 1/4" dowel in the wing center section, about 1/3 of total span and glued to the full-span dowel. The additional spar will assist in handling the higher center section loads.
Jim R.
JRuggiero is offline Find More Posts by JRuggiero
Old Jun 02, 2012, 05:20 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
You can make that wing very strong by using the newspaper glue technique
and adding 3/16" dowels to the leading edge and trailing edges.. No spar needed.
hoppy is offline Find More Posts by hoppy
Old Jun 03, 2012, 05:35 PM
Joined May 2003
Thanks a lot everyone for all the input!
I will look at all the options suggested and make some tests.
This is very interesting:
Cheers!
Fred
Cool "High energy flying" Big Ceres Super Strong at Torrey Pines Phil Davy Slope 12 Mar 17, 2012 07:39 PM
Question OS 1.20 twin enough for SIG 1/4 Cub, full wing? b7gwap Scale Fuel Planes 32 Apr 06, 2010 07:42 PM
Question Building help, whats lighter, a 1/4"x1/4" wood dowel, or a CF arrow shaft? dacaur Foamies (Kits) 7 Feb 05, 2006 11:17 PM
Hot glue strong enough for wing joint ?? .-=banzai=-. Flying Wings 13 Sep 14, 2005 06:19 PM
Making a big wing strong enough FlyingW Electric Plane Talk 1 Jan 24, 2003 10:02 PM
