Old Aug 13, 2011, 09:55 AM
Aussie F3K Pilot
Melbourne, Australia
Joined Jun 2008
Cool
Forton MG (Plaster/Acrylic Polymer) as a mold material..
Hi all,
We are building a DLG wing and fuz mold using a material called Forton MG. It is a Plaster/Acrylic Polymer (not mixed with water) and is available from Barnes Products. The trial mould we have made looks fantastic and it is strong, rock hard, stable and the surface finish is like an Epoxy mould - super smooth and shiny! The best thing is that is quick and easy.
Our DLG thread with some more info is in the Hand Launch section here...
http://www.rcgroups.com/forums/showt...7#post19034630
Has anyone else used a Plaster/Arcrylic Polymer for making molds?
Machineman is offline Find More Posts by Machineman
Old Aug 13, 2011, 10:39 AM
A witty saying proves nothing.
kcaldwel's Avatar
Joined Jan 2007
I think it is the Forton MG process, not MD:
http://www.artmolds.com/gateway/technique/forton_1.htm
Kevin
Edit:
US suppliers:
http://www.sculpturedepot.net/clay-w...ls/casting.htm
http://www.pinkhouse.com/Forton.html
kcaldwel is offline Find More Posts by kcaldwel
Old Aug 13, 2011, 07:14 PM
Aussie F3K Pilot
Joined Jun 2008
Thanks, fixed...
Old Aug 14, 2011, 05:45 AM
I hate propellors
emufingers's Avatar
Australia, SA, Normanville
Joined May 2009
Originally Posted by Machineman View Post
Hi all,
What are you using to seal the mould surface and what release agent for epoxy fuz?
emufingers is offline Find More Posts by emufingers
Old Aug 15, 2011, 07:55 AM
Aussie F3K Pilot
Joined Jun 2008
We don't need to seal the surface of the Forton mold as the finish is already smooth and shiny like an Epoxy mold.
I use a normal Epoxy wax (Canabra) on the plug and they release really easily. I have never used PVA (never needed to).
Old Aug 15, 2011, 09:28 AM
Joined Dec 2006
look great! did you add any additives like cabosil to thicken the mixture? also, do you think adding graphite powder like in the epoxy molds would help here?
thanks!
noobee is offline Find More Posts by noobee
Old Aug 15, 2011, 06:04 PM
Aussie F3K Pilot
Joined Jun 2008
Hi,
No additives. We mixed the two parts together as per the instructions and poured it on. It has a natural thickness and stickiness already.
One thing to do once you have poured in the first coat is to run a stick around the corners of the plug to eliminate any air bubbles.
No idea on the Graphite powder, might be worth experimenting with.
Old Aug 15, 2011, 09:52 PM
Thermal Wrangler
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
On the Forton bandwagon
Molded up a bee-sting (it's a tail-cone) for my Estrella.
Tried Forton which worked well bar a few bubbles (it needs more "kneading" while laying it up) but I molded it wrongly because it didn't have an "opening".
Rushed home at lunch today and feeling brave I started a cut with a hacksaw then finished it off with a bandsaw.
A bit of sanding and it's fixed.
It didn't chip during the process. This is looking promising.
Chris.
DrFragnasty is offline Find More Posts by DrFragnasty
Old Aug 16, 2011, 02:31 AM
Aussie F3K Pilot
Joined Jun 2008
Chris (from planet Forton),
Looks good, well done!
The fact that it did not chip is indeed very promising!
Also, I spoke to the Barnes technical team about adding the Aluminium powder that you used and they said not to use it. 1. The material is already very hard, 2. The Aluminuim does not emusify with the water based Acrylic Polymer properly and 3. They said the Aluminium can be explosive in the water based Acrylic Polymer.
Worth giving a miss on the next mould.
Cheers,
Marcus
(fellow Fortonian)
Old Aug 16, 2011, 07:49 AM
working to the closest cm
jirvin_4505's Avatar
brisbane australia
Joined Nov 2002
Chris.
nice work Chris
Have you had a play with the alternate (pva+plaster) you listed in the DLG thread?
cheers jeff
jirvin_4505 is offline Find More Posts by jirvin_4505
Old Aug 16, 2011, 10:48 AM
Thermal Wrangler
Launceston Tasmania
Joined Mar 2004
Hi Jeff, not yet. I'll wait until the Forton Acrylic - Poly liquid runs out then give it a go.
Chris.
Old Aug 16, 2011, 10:55 AM
Traian's Avatar
United States, GA, Roswell
Joined Mar 2008
Compatibility
Is Forton compatible with Frecote 770
Traian is offline Find More Posts by Traian
Old Aug 16, 2011, 06:00 PM
Aussie F3K Pilot
Joined Jun 2008
I assume so and don't see why not.
I use my current PLP 10 wax on every different surface I have ever moulded from: epoxy, timber, glass, malamine, plaster, Forton, steel, PU, so it should be OK. also, plaster is not really a glue (like epoxy) that wants to stick to anything, so I have pulled plasters from surfaces with no wax.
If in doubt do a small trial piece.
Cheers,
Marcus
Old Aug 17, 2011, 07:06 AM
Traian's Avatar
Joined Mar 2008
Parts
Can someone share in their personal experinece in using these molds. Maybe some part pictures. I see a bunch of achitectural and live casting but mo plane parts??????????
Old Aug 17, 2011, 07:46 AM
Thermal Wrangler
Launceston Tasmania
Joined Mar 2004
Just finished waxing 5x, painted and drying ready for a test lay-up...you can't rush this ;0)
Discussion Resin Infused MDF as CNC plug/mold material Machineman CAD/CAM 7 Jun 19, 2010 06:45 PM
Discussion acrylic shopline ppg paint as paint in mold? geostomp Composites Fabrication 14 May 24, 2010 11:40 PM
Discussion Need Help Making a Plaster Mold screamin' eagle Slope 28 Oct 02, 2007 10:53 AM
Silicon mold + plaster?? chetosmachine Composites Fabrication 4 Nov 16, 2005 04:28 AM
Question What can I use to release resin from a plaster of paris mold? Picoflyer Composites Fabrication 2 Oct 01, 2005 12:37 PM
