Old Dec 16, 2009, 05:08 PM
Joined Dec 2009
Blade mCX trim problems
Hi - Just a question I was hoping someone might answer. My Blade mCX tilts to the right and will even tilt and hit the ground on slow take offs. I have adjusted the to the end ranges with little improvement. I have tried new batteries as well. Also it is very slow moving forward. Any help would be greatly appreciated. Thanks B
bheli is offline Find More Posts by bheli
Old Dec 17, 2009, 05:44 AM
A man with too many toys
United States
Joined Feb 2001
You probably need to adjust the link between the servo and the swashplate.
RC Man is online now Find More Posts by RC Man
Old Dec 17, 2009, 07:18 AM
SCF
Joined Nov 2009
Put your mCX on a level surface and looking at the nose of the bird, notice the orientation of the servo arms as they attach to the swash plate. Unless you set up your mCX specifically for different types of flying, they should be parallel to the surface. They should look pretty much even. If not, adjust them.
SCF is offline Find More Posts by SCF
Discussion Blade MCX trim settings lpurt Coaxial Helicopters 4 Jan 08, 2013 05:44 PM
Discussion Problems binding new blade mcx DazaCX007 Australia 10 Dec 27, 2009 05:25 PM
Discussion Blade MCX Trim Issue (spins left) energeezer Coaxial Helicopters 3 Feb 27, 2009 08:38 PM
Discussion Blade MCX Trim Buttons Lama2MetalHead Coaxial Helicopters 21 Jan 14, 2009 01:01 AM
Discussion Blade MCX Battery Problems c45671234 Coaxial Helicopters 20 Dec 26, 2008 11:07 PM
