Old Dec 11, 2009, 02:37 AM
Project Tormentor is flying!
United States, WA, White Salmon
Joined Nov 2005
rv voltage regulator?
Both my video TX and camera are powered by 12 volts, so I've been using a tiny 350mah 3s lipo. But I would like to power them off the main flight battery, so I ordered the Range Video linear 12volt regulator. My question is, will this hold a steady 12 volts to my camera and VTX even as my flight battery drops as I fly? And will it filter out the noise that the esc and motor generate?
philthyy is offline Find More Posts by philthyy
Old Dec 11, 2009, 05:15 AM
trappy's Avatar
Austria
Joined Feb 2007
It will filter the noise but it won't hold a steady 12V (it's drop-down, not step-up).
trappy is offline Find More Posts by trappy
Old Dec 11, 2009, 05:25 AM
Questionable judgement
bracky72's Avatar
Charles Town, WV
You would be better off using one of these.
http://www.dpcav.com/xcart/product.p...7&cat=0&page=1
bracky72 is online now Find More Posts by bracky72
Old Dec 11, 2009, 07:58 AM
pedantik's Avatar
Asheville, NC
Joined Jul 2009
I am doing the same thing philthyy. I came across this:
http://www.dimensionengineering.com/AnyVoltMicro.htm
It should do the trick! Hope it helps.
pedantik is offline Find More Posts by pedantik
Old Dec 11, 2009, 08:57 AM
bracky72's Avatar
Charles Town, WV
The anyvolt are known to be noisy so make sure you do appropriate range testing to ensure you aren't affected. I have used one with success so you must try and see for yourself.
Old Dec 11, 2009, 09:25 AM
pedantik's Avatar
Asheville, NC
Joined Jul 2009
Hey bracky72,
I know that success can vary drastically setup by setup, but what have you had the best luck with? I know you've gone a mile up, so your opinion holds quite a bit of weight with me. Are you running power from the balance plug or from the dean's?
Old Dec 11, 2009, 11:22 AM
bracky72's Avatar
Charles Town, WV
For a 12 volt system I grab power straight from the esc dean and run it through a LC filter and then on to the tx and camera.
I've never noticed any loss of performance as the lipo drains to empty so I don't bother with a step up regulator. Best to keep things simple if you can.
If I was running 4 cells I would use one of those nifty switching regulators from nghobbies. I've been meaning to pick one up to try it.
Old Dec 11, 2009, 11:53 AM
trappy's Avatar
Austria
Joined Feb 2007
bracky: highly recommended you can get the RECOMs too and add a 470uF cap and 100uH choke. Works very well.
Old Dec 11, 2009, 12:41 PM
Houston Texas
Joined May 2008
Question: are brushless motors noiser than brushed?
edragon is offline Find More Posts by edragon
For Sale Align RCE B6X Bec Voltage Regulator + 1900 MAH 2 cell Lipo + 5.1 Step down for tail djdaveq Aircraft - Electric - Power Systems (FS/W) 0 Dec 02, 2009 11:43 AM
Discussion Voltage regulator and amps ratings? Masterpiece DIY Electronics 10 Sep 19, 2009 08:10 AM
Help! Voltage Regulator dumbthumbs Batteries and Chargers 10 Sep 15, 2009 10:52 AM
For Sale F/S: Align RCE-B6X Voltage Regulator with TWO Lipo's patterkid Aircraft - Electric - Power Systems (FS/W) 1 Sep 14, 2009 09:23 AM
Sold Align RCE-B6T voltage regulator inteleric1983 Aircraft - Fuel - Helis (FS/W) 0 Sep 01, 2009 09:42 PM
