Old Jan 04, 2003, 07:42 PM
Emission is offline
Find More Posts by Emission
Thousand Oaks, California, USA
Joined Jan 2003
First post... totally confused about charging!
I've searched the archives, and read many posts... but I still can't figure out this whole battery/charging system!
I've got a new Zagi-X with the KR-1700AU battery (I've got two of them). My charger is a PF-12 Park Flyer plugged into an A/C outlet (charge at home - fly at the field).
I charged the first battery at 800 mA for 90 minutes. I charged the second battery at 1200 mA for 90 minutes. Which is correct? Should I charge them both at 1700 mA? I want long battery life, and good run times.
Also, should I completely drain the batteries before re-charging (hook them up to a small bulb and let them drain)? Would this help?
Thanks in advance!
Emission is offline Find More Posts by Emission
Old Jan 04, 2003, 07:52 PM
Capt. Electron is offline
Find More Posts by Capt. Electron
Senior Moment Member
Virginia Beach, Va.
Joined Jan 2002
Welcome to the EZone!! Confused? You'll fit right in here.
Yep, charge them at 1700 mA. That's called 1/C, or 1 times the cell capacity.
They usually perform better after a few charges.
No need to discharge them down, just charge, fly, charge, fly.....
Have fun..............
Jimmy
Capt. Electron is offline Find More Posts by Capt. Electron
Old Jan 04, 2003, 08:33 PM
HankF is offline
Find More Posts by HankF
Joined Apr 2000
Hi Jimmy, let's not mislead the new chap. You said it right: "1 times cell capacity" but 1/C means 1 divided by cell capacity. It should be 1C.
Regards,
Hank
HankF is offline Find More Posts by HankF
Old Jan 04, 2003, 09:16 PM
Emission is offline
Joined Jan 2003
OK. Thanks for the quick replies.
In idiot/novice/layman terms that means turn the dial to 1700 mA and push the start button? So, my unit will charge for 90 minutes, then trickle (1/10) for another 90 minutes. Do I need to pull the battery after 60 minutes?
What if I want to plug it in and walk away? My guess would say ~1200 mA @ 90 minutes is the same as 1700 mA @ 60 minutes.
Sorry for another lame follow-up question.
(BTW - I flew gas models about 15 years ago then put them in storage one day - never to fly them again. About two months ago, I saw some guy flying a Zagi at a park. It was quiet, clean, and he was not at an 'airfield' for RC. I was blown away at how far electric planes have come! I asked for one for X-Mas (and Santa delivered). It flew for the first time on Wednesday, and it's not going away anytime soon.)
Old Jan 04, 2003, 11:24 PM
HankF is offline
Joined Apr 2000
We'd need to know what your charger can do. Who makes/sells the unit you have. Is it a peak charger? Is the charge current selectable? etc.
Hank
Old Jan 05, 2003, 12:29 AM
Emission is offline
Joined Jan 2003
It is a PF-12 Park Flyer AC/DC Peak Charger by WattAge
Old Jan 05, 2003, 12:49 AM
FlyByMike is offline
Find More Posts by FlyByMike
Pittsburgh, PA
Joined Jan 2002
You seem to have the basics done OK (you've said: ~1200maH x 90 min same as 1700mah x 60 min? and pull after 1 hour?). Just have a little confidence You shouldn'y need any trickle charges, be careful to not leave them totally unattended, and notice how hot they get (heat shortens batt life).
Go for it
FlyByMike is offline Find More Posts by FlyByMike
Old Jan 05, 2003, 01:01 AM
freq is offline
Find More Posts by freq
soft yummy goodness.
freq's Avatar
North Jersey, USA
Joined Oct 2001
Welcome to Ezone! For an excellent primer on charging and things related, see the following:
www.rcbatteryclinic.com/
- chris
freq is offline Find More Posts by freq
Old Jan 05, 2003, 06:29 AM
Virginia Beach, Va.
Joined Jan 2002
You're right Hank, that was a critical typo. But at least I didn't type 1700 amps for a charge rate.
Jimmy
Old Jan 07, 2003, 03:01 PM
oldman is offline
Find More Posts by oldman
washington state
Joined Dec 2002
Just my $.02 worth.
I was always led to believe that any new pack
should be slow charged the first time, and a new pack just soldered togather MUST be slow charged to equalize
the cells. Also a pack that has been fast charged a few times
should be slow charged once in a while.
Now a question. Does this hold true for the new current
state-of-the-art batteries being sold today ?
I'm new to park / slow flying, but I started flying electric
around 1994. Electric-Cub, PT-Electra, Electra Streak,
Spectra Glider. If you think 6 or 7 AA cells are heavy
try 12 sub-c cells. A lot of the cells I fly with today I started
out with in 1994.
This is great group you have here, your never to old to learn
something new (and I know cause I'm old) somedays anyway.
OldMan
oldman is offline Find More Posts by oldman
Old Jan 07, 2003, 07:43 PM
Virginia Beach, Va.
Joined Jan 2002
oldman,
You're absolutely right, it's pretty well established practice to give them that initial first slow charge. And again from time to time just to keep the entire team pulling together. I just failed to mention it.
See, told you I was pretty confused.
Jimmy
Old Jan 08, 2003, 10:48 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
1. Slow charge all new packs at 0.1C for 16 hrs. Use as is.
2. After initial slow charge and a normal discharge cycle, charge at 1C.
C= cell capacity in mah/1000
C = 1700mah battery/1000 = 1.7A
Set charger to deliver 1.7A
A fully discharged battery will take about 1 hr to charge.
hoppy
hoppy is offline Find More Posts by hoppy
Discussion Totally Confused About Electric Motors NCMechanix Beginner Training Area (Aircraft-Electric) 4 Jan 08, 2006 09:50 AM
First 'real' radio - slightly confused about crystals Transition Radios 4 Jul 29, 2004 11:49 AM
My first post in this forum :) Question about Modeltech Extra 300 JStory Sport Planes 4 Aug 15, 2002 02:13 PM
Still confused about Batteries!!!! willvolny Beginner Training Area (Aircraft-Electric) 15 Jun 07, 2001 02:12 AM
Really confused about the gear ratio.... atsiang Parkflyers 10 May 05, 2001 12:43 AM
