Old Apr 25, 2015, 01:09 AM
MadMonkey572 is online now
Find More Posts by MadMonkey572
Boooriiiiing.
MadMonkey572's Avatar
United States, TX, Roanoke
Joined Sep 2006
Alternative power systems
At my club, we're flying a lot of full-contact combat with pusher jets (usually profile F-22s). We use the typical 2212/6 2200kv motors with 6X4 props, and these tend to work pretty well.
Unfortunately, a lot of the time we run full throttle, and even then our acceleration is slow from a stop, usually after a very hard turn.
I'd like to experiment with some other power systems to see if I can improve low-end acceleration, while not having to run full throttle to get decent speed. What I'm considering is a motor that can run a cut-down higher pitch prop efficiently (max of about 7" diameter). Guys have tried higher KV motors, but with such draggy airframes they haven't seen much of a performance increase.
AUW is about 13-14oz (that's a well-used airframe with a lot of hot glue on it, so it might be lighter when new) without the battery, which is a 3S 1300-1800 but I'd like to try a 4S setup as well.
I could get away with a heavier motor but not by a lot, these things are somewhat sensitive to weight as I know you guys know.
Any suggestions on where to start?
MadMonkey572 is online now Find More Posts by MadMonkey572
Old May 06, 2015, 02:43 PM
kcolraw is online now
Find More Posts by kcolraw
Kcolraw
United States, NC, Asheville
Joined Feb 2015
You could try an 2822/17 1100kv with either a 7x6 or 8x6 apc prop. Just watch the Temps with a 8x6.
kcolraw is online now Find More Posts by kcolraw
Discussion Alternate airframe for GP flatout Brushless power system? TommyB Foamies (Kits) 1 Oct 30, 2006 06:57 AM
Any cheap alternative for a power system for the Hyperion Mini-Cap? (36.5") gotime242 Power Systems 2 Aug 30, 2005 10:15 AM
any alternative power systems for fantastic t-6? BuzzBomber Power Systems 13 Apr 29, 2004 12:13 PM
Anyone trying an alternate power system for the Cargo? AMTJIM Foamies (Kits) 0 Nov 04, 2003 11:23 AM
Alternate power system for P38 ( is it possible?) BlueAce Scale Kit/Scratch Built 8 Nov 20, 2001 03:48 PM
