Old Apr 11, 2015, 09:24 PM
badadas is offline
Find More Posts by badadas
Joined Apr 2015
Help
Hi all just bought a 450x blade, was hovering when bought, but found main shaft was bend, replaced and also some bad link, fix up but heli is not lifting off, please advice what settings have to be done?
badadas is offline Find More Posts by badadas
Old Apr 11, 2015, 09:51 PM
sonicboom24 is offline
Find More Posts by sonicboom24
United States, FL, Miami
Joined Nov 2010
Did you check your pitch settings? Unplug your motor (for safety reasons) and see what your pitch range is. Do you have a pitch gauge to check?
sonicboom24 is offline Find More Posts by sonicboom24
Old Apr 12, 2015, 01:22 AM
sprint11 is offline
Find More Posts by sprint11
sprint11's Avatar
Joined Dec 2013
also not sure what tx your running but make sure in reverse your pitch is reversed.
sprint11 is offline Find More Posts by sprint11
Old Apr 12, 2015, 05:15 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Welcome to the forum
The heli "was hovering when bought", but was that with your present receiver and transmitter, or was it the vendors?
With the blades off and the motor disconnected, the first thing you need to check is that all three swash servo arms are horizontal when the throttle/collective stick is at mid point, that the swash is level, and that the swash stays level as it moves up and down in response to throttle/collective stick movement.
If that all checks out, then you need to check your pitch at low, mid, and high stick position, using a pitch gauge. I normally aim for about -3 degrees at zero stick, +3 degrees at mid stick, and +12 degrees at full stick position.
abenn is offline Find More Posts by abenn
Wanted Help! I am poor but want to fly too :) do a good deed and help a beginner get flying protopilot Aircraft - Electric - Multirotor (FS/W) 19 Apr 19, 2015 05:15 PM
Discussion Pls Help!!! New & Need Urgent Help KLI Multirotor Talk 8 Dec 25, 2014 02:08 AM
Help! Admin help or sales help ASAP Waterbound Trader Talk 4 Dec 16, 2014 06:07 PM
Help! Help-help-help-please chuckie4654 Competition Aerobatics 2 Dec 04, 2014 11:48 PM
Discussion Help help help !!! Opie420 Large Electric Helis 5 Nov 26, 2013 05:43 AM
