Old Jan 17, 2015, 04:41 PM
Procrastinator1 is offline
Find More Posts by Procrastinator1
United States, SC, Hilton Head Island
Joined Feb 2014
Build Log
DJI Phantom 2 Flir Tau 2 Thermal Camera Build
I recently had an inspection that required the use of a thermal camera to inspect a solar panel field for failed units. I have numerous thermal imagers, but most too big or too bulky to be used on a multi. The tau series is impressive for its size, but it is not the most plug and play camera on the market. The other issue is there is no readily available brushless gimbal with a manual tilt option. First, we installed it on our workhorse S900, but it was hard mounted to the gimbal rails with the ability to manually tilt. That obviously became a huge pain because you could never get the camera the exact way you wanted it. We researched many different posts and setups, but none were going to work for the exact way we wanted it to. After lots of trial and error, we have finally got a solid unit on our hands. We have steady, jello free video installed on a light, nimble and quick to deploy phantom 2. The phantom 2 is a good platform to install it on, as the Flir Tau 2 weighs only 5 more grams than a Gopro, and is extremely reliable. The results are pretty stunning, and its a pretty simple install once you know the pitfalls of installing a tau 2 on the phantom, and what you can do to correct it. Here is the list of the parts needed to have a complete, RTF thermal imaging phantom.
  • Phantom 2 Flir Tau2 Thermal UAV
  • DJI Phantom 2
  • DJI 2.4ghz Datalink (Waypoints)
  • DJI AVL58 Video Downlink
  • DJI Mini IOSD
  • DJI FPV HUB
  • Flir Tau2 Thermal Camera 336 (13mm Lens)
  • Flir Tau2 VPC Module
  • Beholder Lite 2 Axis Brushless Gimbal
  • Right Angle MCX Cable
  • Right Angle MINI USB to USB Male
  • 12-26 Volt to 5 Volt Regulator
We went with the 336 model with a 13mm lens. For the price, the 336 is the best option. If you are on a tight budget, the 168 model is ok, but the small price increase relative to quality for the 336 is major. The 640 is an amazing camera, but at more than double the price of the 336, we decided it wasn't necessary as of now.
The installation is pretty simple, but some minor soldering is required. The beholder lite gimbal is almost a perfect fit, and the stock gopro gimbal settings are pretty close. We did need to order some custom right angle cables, as the way the Tau 2 is mounted on the gimbal leaves very little room for straight plugs. You also need to convert the phantom 2's 12 volts to 5 volts to power the Tau 2, which is relatively easy to do with a car usb charge adapter.
Below is some up-close images of the install, and how everything is laid out. We also actively use the 2.4ghz datalink for waypoints, especially when performing inspections. We also did a quick demo video showing the recording quality of the camera, along with the gimbal performance.
DJI Phantom 2 Flir Tau 2 Thermal Imaging UAV (4 min 40 sec)
You can also view details, step by step how-to and tips and tricks for the installation at http://www.nue-av.com/#!DJI-Phantom-...C-629BBF0BC19E
Here is some images of the final installation and how it is physically mounted to the phantom. If you have any questions, feel free to message me here or through our website, www.nue-av.com
Procrastinator1 is offline Find More Posts by Procrastinator1
Old Jan 17, 2015, 05:02 PM
gtojon is offline
Find More Posts by gtojon
Photog & Puter Tech
gtojon's Avatar
United States, MN, St Peter
Joined Apr 2013
Thank you for posting .... very informative!
Cheers, Jon
gtojon is offline Find More Posts by gtojon
Old Jan 18, 2015, 11:25 AM
Joined Feb 2014
No problem! When I was researching it there was a few people who have done it successfully. Unfortunately some used larger rigs, big gimbals, or didn't have tilt control. It was definitely trial and error, as I wired it up originally with just pos and neg power leads coming from the usb to the adapter. The camera would not turn on and operate and I was racking my brain trying to figure out why. It turns out the male standard usb connector needs the connectors metal housing as it is some sort of ground. When not using the male usb connector, and just power leads, only 0.5 amps run through the pins. I also had to mess with the flir tau's gui settings, as I was getting some washout of contrast when there was a vast difference of temperature between two items. If there is any questions feel free to message me.
New Product Flir thermal camera for $350 Rolikei FPV Equipment 11 Apr 29, 2015 09:05 AM
Mini-Review Upgraded DJI Phantom 2 with FLIR Thermal Camera - Ready to Fly thangchelsea Multirotor Talk 0 Dec 15, 2014 12:00 PM
Discussion Flir tau thermal camera to lightbridge. NaterPin Multirotor Talk 1 Oct 22, 2014 01:53 AM
For Sale Good deal on FLIR TAU 2-324 joegermano1 FPV Equipment (FS/W) 3 Oct 21, 2014 06:56 PM
Discussion Phantom 2 with Flir Tau 2 Thermal Camera thangchelsea Multirotor Talk 8 Mar 22, 2014 09:47 AM
