Old Aug 15, 2013, 06:47 AM
vtolman is offline
Find More Posts by vtolman
Cambodia, Phnom Penh, PP
Joined May 2004
Bicopter Plane design help needed
Anyone got any links to a successful Bicopter Plane build log post with good info.
I want to build a model similar to the (photo) layout I made in 2005 with improved stability (this did not have a FC board..only gyros)
Basically a model like a plane with a wing and tilting outer front motors for fast forward flight, added lift, duration, some glide ability, loops, and stable hover in head winds and pirouettes etc.
Can taxi around and hover take offs landings etc.
Any proven concepts you guys have done or seen.... let me know please.
Maybe a Bicopter or Tricopter proven concept with tilting front motors (without wing) will help me with ideas also.
I don't want to reinvent the wheel if some clever person has done it and has all the answers with specs on ....flight controller mods settings mixing or TX flight modes etc.
This gets complicated as roll and yaw reverse from hover to forward flight etc.
Anyone nailed this yet.
Mine flew good and hovered ok with tilting from hover to 45deg BUT transition down to horizontal forward flight proved very tricky without an onboard FC board accelerometer gyro mixing, TX mixing, flight modes etc.
I want another crack at this concept.
No collective or cyclic designs please and no ailerons ...just simple fixed tilting props and maybe a small tail motor if necessary.
Thanks in advance for any leads you can offer.
vtolman is offline Find More Posts by vtolman
Old Aug 15, 2013, 04:39 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Building a bicopter with the MultiWii or KK board will help you get up to speed using the latest tech in your awesome bicopter airplane. MultiWii is the better option if you need to touch the code and are fairly new at the whole coding process.
By the time you have played with that something more to what you are asking for will probably be available.
RCvertt is offline Find More Posts by RCvertt
Old Aug 16, 2013, 07:16 AM
v22chap is online now
Find More Posts by v22chap
v22chap's Avatar
United States, IN, Granger
Joined Jan 2003
Hey welcome back Vtolman ... good to see you still flying Vtols !!!
Like Aaron said .. Multi Wii boards are much better now than any gyro and there have been several guys do bicopters ... matter of fact one has marketed his design .It is only a bicopter .. but probably could be re worked to tilt and fly as airplane too .
Here is his thread :
http://www.rcgroups.com/forums/showthread.php?t=1620636
In another thread it pointed to the online store that carries it .. but I can't find it right now . Maybe pm Samie and find the store or guy who built it for help .
v22chap is online now Find More Posts by v22chap
Old Aug 16, 2013, 11:57 PM
vtolman is offline
Joined May 2004
Thanks RC Vertt Aaron and v22chap Larry.
Its been many years and I'm just starting back into the hobby actually.
I still have that model in the photo but its back in Australia.
I just got a kk2.0 for a scratch built tricopter with cam I've just finished and ready to test but I don't yet have a TX so Im patiently waiting on the Frsky Taranis ......who knows when that will be.......they are slow with getting stock made or sorting out quality problems whatever.
Yes I'm also thinking of a Multiwii pro (for AP and this idea)
But Im looking for someone who has made a heads start with program mods and testing.
Not my field of knowledge yet.
I see HappySundays is working on a V22 in his build blog to do all the tricky transition functions on a kk2.0 but he is yet to test it.
His Thread I guess you've both seen is- Osprey V22 with real transitional flight controller -with kk2.0 mods in his OpenAero2 V1.3
Hi LARRY is it ?..v22chap good to here from you its been a long time, I've been living in Phnom Penh Cambodia for 18 months of all places, I tried the Philippines but it wasn't for me and I lived in Thailand for 6 months.
I mail order everything here...as this country is back in the stone age.
I cant find any online store selling a kit you mentioned so I emailed Samie as you said.
WOW......I'm really surprised after ALL these years we cant buy an off the shelf reasonably priced fixed prop V22 kit with and/or a programmed FC board.
I've seen some other guys DIY projects but nothing perfected and the info is vague.
I hope Aaron's right and its all just a few months away.
Thanks guys.
Kingsley
Old Aug 19, 2013, 05:59 AM
v22chap's Avatar
Joined Jan 2003
Yep .. Larry it is ... and yes Tom Mast has built the altimate V-22 (with a price ) ... and maybe he will surprize us and make a cheap airplane prop version . as he has talked about it .. wouldn't hold my breathe though
Old Apr 04, 2015, 03:49 AM
vtolman is offline
Joined May 2004
Bicopter and tricopter vtol planes
I haven't made the hybrid yet but I did make a bicopter vtol plane and a tricopter vtol plane.
I couldn't make my mind up .... so - I made both.
(The hybrid would be like the bicopter vtol plane with front motors a bit more forward and a smaller tilting tail motor)
Both models fly and hover well but pitch is as expected but manageable for the Bi.
Both inbound transitions are easy and don't require much programming as it's already flying and simply adds vertical thrust and slows down into a hover.
Outbound transition on the tri requires much more tinkering with the P and I settings on the FC to smooth it all out - it can be Very Scary and exiting doing backflips if not setup correctly
I'm using a Kk2.1.5 flight controller with openaerovtol firmware on both planes thanks to the geniuses who wrote it and tested it and wrote acurate instructions on how to use it.
The Tri tilts both front motors together through 90 deg with one tilt servo and has the usual ( tricopter) tilting rear yaw servo.
The rear motor blends in and out to automatically turning on and off the motor for hover or forward flight according to how you set up the FC.
The Bi uses one servo to tilt each motor which does yaw and pitch in hover then tilts to horizontal for forward flight and stays still.
It needs strong light servos which travel about 110 deg so linkages won't work - direct mounting is essential as you don't want play at each end of travel.
All my tilting servos are all corona DS 238MG.
FC turns off the gyros and cancels yaw and pitch servos and adds rudder input to differential throttle for forward flight yaw control.
Both can (if needed) fly forward without ailerons but under power using yaw motor control.
Or it can be mixed to aileron to help turns.
Flat spins under power ? - I haven't tried it yet.
It's early days with both of these projects and the more I crash the better I get
Old Apr 04, 2015, 08:43 AM
v22chap's Avatar
Joined Jan 2003
Hey Vtolman ... great to see you back in the VTOL section and still building ... the KK 2.1 with Happys VTOL loaded is a whole lot better than the old arcmax gyros ,eh !!!
Old Apr 05, 2015, 10:01 PM
vtolman is offline
Joined May 2004
Thanks Larry
Yes the kk within Openaervtol is a brilliant breakthrough for the vtol enthusiasts.
It is very customizable for the vast diversity of vtol designs people can dream up.
It's been a long time coming as I have waited since 1994 for this missing link in the vtol puzzle, but I sure didn't think it would take almost 20 years.
Upside was, back in those evil dark ages the old arcamax gyros were plug and play - we didn't have much to rack our Neanderthal brains over by now reading the endless labyrinth of internet pages and forums until we finally crack from brain overload and go for a beer
With Openaerovtol (and my Taranis) its like I still don't know what I don't know - everything they can do.
It's brilliant - I can't wait to see what's in the future.
Old Apr 06, 2015, 12:02 PM
v22chap's Avatar
Joined Jan 2003
Did you happen to see Tom's Bicopter ... it seems to fly really good and uses kk 2
http://www.rcgroups.com/forums/showthread.php?t=2057761
Discussion Design Build a RC plane - Engineering Design Competition - Need Help Briickhouse Electric Plane Talk 21 May 29, 2013 12:08 PM
Build Log need help making first plane design builder bob Scratchbuilt Indoor and Micro Models 44 May 19, 2013 09:47 AM
Help! Need help with bicopter build! vgorkum Scratchbuilt Multirotors 33 Feb 19, 2013 03:54 AM
Wanted Help needed - electronics design and mfg danphillips Aircraft - Electric - Multirotor (FS/W) 3 Jan 12, 2013 07:42 PM
