Old Aug 19, 2013, 08:58 PM
Hance is offline
Find More Posts by Hance
Expo is built into my thumbs
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
Maybe it's just the perspective in the video but it seems much faster than I had imagined.
Hance is offline Find More Posts by Hance
Old Aug 19, 2013, 11:58 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
yeah, it will tear around at a respectable speed if you give it full power. As it comes out of the box it's hard to keep the nose down when flying at WOT, but increasing downthrust helps.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Sep 02, 2013, 07:26 PM
Flyboy70 is offline
Find More Posts by Flyboy70
Joined Apr 2001
I have a problem with my G2 Auto gyro. It does not seem to have a lot of power..When I run it up to full throttle it will run wide open and a secomd or two and then it will back off some. Has anyone experienced that. I am thinking of changing the speed control to see if that will help.. Any other suggestions will be appreciated. Thanks
Flyboy70 is offline Find More Posts by Flyboy70
Old Sep 02, 2013, 07:48 PM
pcphill is offline
Find More Posts by pcphill
Plain Broke and Broke Planes!
pcphill's Avatar
Hoschton, GA
Joined Jul 2003
Mine has lots of power, I'm flying it about half throttle. I would suspect the esc if everything else seems good. You are turning off the rotor motor after it's up to speed?
pcphill is offline Find More Posts by pcphill
Old Sep 02, 2013, 08:01 PM
pcphill is offline
pcphill's Avatar
Hoschton, GA
Joined Jul 2003
I've now had two good flights with the Auto G with ROG takeoffs. Even with the grass it's no problem getting airborne. Orientation at any distance is a problem for me, there is very little indication of whether the rotors are level. I'm trying to see the landing gear and use the wheels to judge it. I'm bleeding off too much rotor speed in my landings and it's making some rapid unplanned attitude changes, but I'm getting better. Latest video here. This was taken with my Lumia 928. Check out the gnats swarming the camera. We abandoned the field right after this...
Auto G: first decent flight (2 min 1 sec)
Old Sep 02, 2013, 09:47 PM
David Hogue is offline
Find More Posts by David Hogue
Go Dawgs!!!!!!!
David Hogue's Avatar
USA, NC, Clayton
Joined Feb 2001
I've been thinking about adding a Guardian or something similar to my PT Gyro just for that orientation issue, Phil. I have the same issues when it gets too far away, and too far isnt very far
David Hogue is offline Find More Posts by David Hogue
Old Sep 02, 2013, 09:53 PM
pcphill is offline
pcphill's Avatar
Hoschton, GA
Joined Jul 2003
Not a bad idea...
I probably won't because I'm stubborn though.
Old Sep 06, 2013, 01:54 PM
Aberdeen
Joined Mar 2006
Sounds like a battery with 'saggy' voltage. Try another battery, preferably a decent quality new one.
Old Sep 06, 2013, 01:59 PM
Aberdeen
Joined Mar 2006
I'm not sure how well a stabilizer would work a gyrocopter. Controls can work in strange ways which might confuse a stabiliser. If you try one make sure you have it set so that you can disable it in flight if it all goes 'funny'.
Old Sep 06, 2013, 04:57 PM
Flyboy70 is offline
Joined Apr 2001
I think you are right. I have a couple of other batterys
I can try. Thanks for the input
Old Sep 07, 2013, 03:45 AM
Go Dawgs!!!!!!!
USA, NC, Clayton
Joined Feb 2001
The PT is dc for pitch and roll, and standard rudder, so not much different from an airplane. A club member has one I may be able to borrow and test.
Old Sep 07, 2013, 07:01 PM
Flying_Flair is offline
Find More Posts by Flying_Flair
United Kingdom, England, Hemel Hempstead
Joined Feb 2010
There is a thread where a guardian has been tried on an Autogyro - worth a look,
http://www.rcgroups.com/forums/showthread.php?t=1785632
Malcolm
Flying_Flair is offline Find More Posts by Flying_Flair
Old Mar 12, 2015, 12:40 AM
onefastxp is offline
Find More Posts by onefastxp
crashing build's character.
United States, AL, Dora
Joined Mar 2008
has anybody had problems with their pre rotator shaft bending or warping and causing vibration to the gyro copter?
onefastxp is offline Find More Posts by onefastxp
Old Mar 12, 2015, 04:56 AM
pcphill is offline
pcphill's Avatar
Hoschton, GA
Joined Jul 2003
Mine has been grounded long term due to a broken motor mount. I wasn't having a problem previous to that...
New Product Durafly AUTO-G Gyrocopter Sammy70 Auto Gyros 2314 Yesterday 06:31 PM
Yippee! Hobbyking Durafly AUTO-G Autogyro-Gyrocopter joseico90 Auto Gyros 84 Dec 25, 2014 07:49 AM
Discussion Pusher Auto G Jockadopolus Auto Gyros 31 Feb 27, 2013 11:45 AM
Sold Durafly Auto-G Gyro and my HK horror story porcia83 Aircraft - Electric - Airplanes (FS/W) 7 Jan 09, 2013 12:38 AM
Sold Durafly AUTO-G Gyrocopter luvmykids2 Aircraft - Electric - Airplanes (FS/W) 3 Dec 17, 2012 02:30 PM
