Old Feb 06, 2012, 02:27 PM
hog2soar is offline
Find More Posts by hog2soar
hog2soar's Avatar
Central California
Joined Jan 2010
Question
Elevator mix with throttle or not
I'm getting ready to maiden my Oly III,and was wondering if any of you mix your elevator to your throttle during launch? Or do you just thumb it?
Eddie
hog2soar is offline Find More Posts by hog2soar
Old Feb 06, 2012, 02:32 PM
Leadchucker is offline
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
United States, NJ, North Wildwood
Joined Sep 2008
I thumb it, but that's just me.
Leadchucker is offline Find More Posts by Leadchucker
Old Feb 06, 2012, 02:33 PM
tkallev is offline
Find More Posts by tkallev
LSF303 / AMA Life Member
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
I do, but if you have no idea how much to use (maiden flight) I would just thumb it rather than make a mistake by putting too much in. A fixed stab/elevator will need much less than a full flying stab.
tkallev is offline Find More Posts by tkallev
Old Feb 06, 2012, 05:23 PM
Kenny Sharp is online now
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Thumb it.... Mine flies under power, where you point it.
Kenny Sharp is online now Find More Posts by Kenny Sharp
Old Feb 06, 2012, 06:14 PM
Lilienthal is offline
Find More Posts by Lilienthal
Lilienthal's Avatar
United States, CO
Joined Nov 2010
You definately want to thumb it at first. Hopefully you can balance out your plane to where it doesn't need a throttle-elevator mix. If not and you are inclined to use a mix, start very low and then work up slowly. The first time I tried a throttle-elevator mix I overdid it and it was pretty exciting for a few seconds while I figured out how to handle it. If your Tx will do it, a bit of delay on the mix is nice.
Lilienthal is offline Find More Posts by Lilienthal
Old Feb 06, 2012, 06:17 PM
Ed Franz is offline
Find More Posts by Ed Franz
You looking at me?
Ed Franz's Avatar
USA, KY, Burlington
Joined Sep 2001
Thumb it. No mix will cover all the variations in launch winds and weather.
Ed
Ed Franz is offline Find More Posts by Ed Franz
Old Feb 07, 2012, 08:20 AM
mcramer is offline
Find More Posts by mcramer
Goshen, IN
Joined Dec 2003
Hi Eddie
I never launch a new model myself. I ask someone else, and that person must know how to launch an electric sailplane, launch it for me. That way, if the model does anything unexpected,
both of my hands are on the sticks and I can correct the problem quickly. If the model pitches up when the motor is on, you may want to use elevator trim or mix elevator with motor.
Good luck!
mcramer is offline Find More Posts by mcramer
Old Feb 07, 2012, 08:43 AM
turn, turn, turn.
Joined Oct 2005
Ed
This is so true!
Old Feb 07, 2012, 05:55 PM
jiafret is offline
Find More Posts by jiafret
Tailspin
Grand Blanc, Michigan
Joined Feb 2006
If you do use a mix, put it on a switch so you can get off of it quickly. I tried it once and went back to flying it out. More trouble than it is worth.
Jack
jiafret is offline Find More Posts by jiafret
Old Feb 07, 2012, 06:30 PM
Piper J3 is offline
Find More Posts by Piper J3
Full Scale Piper Cub Driver
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
I mix elevator with throttle on my Paragon and Sensor 117 both of which I converted to electric. Both have throttle actuated on the gear switch to free up the throttle stick for flap/spoiler. Throttle is either off or 100% full. I maiden a new airframe with no throttle/elevator mix and have a friend hand launch as mcramer mentions – you never know. I first trim the elevator in cruise flight and assure correct CG, then launch again to see how much elevator to compensate for motor. Several factors come into play. With motor launch the wing is flying at much higher airspeed than in cruise flight. High speed means higher drag and because the wing (especially polyhedral) is above the vertical CG, and motor on or near the vertical CG, the airframe will climb. A few degrees of motor down thrust will also negate the climb tendency during motor launch. Either way, by having pitch compensation the climb-out is smoother.
Piper J3 is offline Find More Posts by Piper J3
Old Feb 08, 2012, 02:00 PM
pilotpete2 is online now
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
I've only owned polyhedrals , so I have used a little down elevator mix for as long as I've had a radio with the capability. When I maiden my (new to me) 2M Poly Pulsar this Spring, be assured that one of my fellow fliers will do the launch and there will not be any mix until I see how it responds to power on launch.
Since I spend much time flying aerobatic gas/glow powered models and don't fly full house sailplanes, I'll never use the throttle stick for anything other than thrust. Flaps on the PP will be on the left slider control of the radio. I'm an old dog, so I'm not looking to learn new tricks
This past season, one of our "senior" members (you have to be well into your 80's to be considered a senior at our field) was getting frustrated with his Radian, since it pitched up so much under power. I set up the mix on his DX6i, tried a couple of launches, then handed it back to him. He's a very happy camper now!
Pete
pilotpete2 is online now Find More Posts by pilotpete2
Old Feb 08, 2012, 04:44 PM
williamson is offline
Find More Posts by williamson
Joined Feb 2006
I have instructed several people with their new electric sailplanes (mostly Radians). The technique that I have used is to do a number of hand launches with the motor off to set up a CG and elevator trim that gives a nice flat glide with minimal pitch oscillations.
Having done that, the next step is to hand launch and then ease in some power. This will test whether the nose pitches up or down with power. It usually pitches up. Some elevator-to-throttle coupling is put in and the process repeated. Eventually, we get to the point where the nose doesn't pitch up as the power is cranked up. At that point, higher-power launches can be done without the plane doing a pitch up and death loop. The elevator control is still used to adjust the climb angle on the way up.
williamson is offline Find More Posts by williamson
Old Feb 09, 2012, 07:50 PM
Andy W is offline
Find More Posts by Andy W
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Never. If it needs it that bad, adjust the motor angle to compensate.
..a
Old Feb 09, 2012, 08:43 PM
hog2soar is offline
hog2soar's Avatar
Central California
Joined Jan 2010
Thanks guys
I put 5 degrees of down thrust on the motor when I installed it. I hope that takes care of any bad tendencies it may have.
I'll take it slow and basically do as Williamson said. Hand tosses without power untill I get it trimed. Then hand toss with a small amount of power. Then hand toss with a little more power untill I feel comfortable with what it's doing.
Thanks again,
Eddie
Old Feb 23, 2012, 09:37 AM
rtbates is offline
Find More Posts by rtbates
Joined Mar 2010
I have the same issue with my 2M Minimoa. I thumbed it at first to get the feel than went with 30% down elev at full throttle... Much much easier to fly without all the elev down pressure needed...
rtbates is offline Find More Posts by rtbates
Discussion Optic 6 / Throttle to Elevator mix amalka Hitec/Multiplex USA 2 Jan 17, 2012 01:12 AM
Discussion Aurora 9 and servo slow for flaps with elevator mix slow? Ceeray Hitec/Multiplex USA 1 May 24, 2011 08:50 AM
Question Elevator mix to throttle or educated thumb hog2soar Electric Sailplanes 16 Dec 28, 2010 04:28 PM
Question Motor Down thrust or throttle to elevator mix Hugh P Modeling Science 4 Sep 11, 2009 09:43 AM
Discussion Programming Spektrum DX-7 Throttle/Elevator and Throttle/Rudder Mix Jordonr Radios 0 Dec 04, 2007 08:33 AM
