Old May 16, 2003, 06:59 AM
nick_cool is offline
Find More Posts by nick_cool
y chucu, chucu, chuuuu...
nick_cool's Avatar
Argentina, Buenos Aires
Joined Apr 2003
Pulqui II Project
Pulqui II Project
And here we go again, and this time with a complete new EDF model!
After two months of R&D I already have the figures and the draw of my Pulqui II N°5, I am starting to build it next week. I am assuming to spend 6 months in this project.
The initial spec. are based in a modified 1:14th scale:
Wingspan: 800mm, 31.5”
Length: 840mm, 33.7”
Gross Weight: 1112gr, 39.2oz (estimated)
Wing load: 56.5gr/dm2, 18.8oz/sqinch
Airfoil: Symmetrical, 12.4%
Power: 400W
Fan diameter: 92mm, 3.6”
For the people who don’t know the Pulqui II, here are some photos.
You also have a good summary about the history of Pulqui in:
http://www.ipmsstockholm.org/magazin...ile_pulqui.htm
nick_cool is offline Find More Posts by nick_cool
Old May 17, 2003, 12:14 PM
nick_cool's Avatar
Joined Apr 2003
Another photo from those days
Old May 17, 2003, 01:45 PM
Gordon is offline
Find More Posts by Gordon
Gordon's Avatar
Joined Aug 2000
Hi Nick
Danged if I know how you're gonna fit a 92mm fan and cells into a 31.5" span Pulqui II. I began drawing up a 40" span version for a 90mm Midifan some time ago, and here's a pic of the drawing.
There's not a lot of space remaining outside the ducts, even at that size
Gordon
Gordon is offline Find More Posts by Gordon
Old May 17, 2003, 08:42 PM
nick_cool's Avatar
Joined Apr 2003
Hi Gordon!
The scale you chose (1:13) is the same I have for the fuse (1:14 modified).
At these sizes there is always a little space for the power plant and RC stuff, particularly in EDF models .
Four ways to gain space:
Choosing a bigger scale e.g. 1:11, but it needs a bigger power plant, is a trade off solution.
Using RC glider’s gear, good if you can afford it
Making the fuse wider, good for me
Cheating the fuse’s shape, awful but practical
I will hide the Rx, battery and Aileron servo in the canopy. The elevator servo will be upside between the rudder and the canopy, and it will be horizontally mounted.
The fan and power plant will as be some where between the CG and the tail. Here we have a compromise, in one hand the fan should be near the tail to be more efficient, in the another hand we have to balance the model (CG) and try to have the smaller momentum we can. The batteries will be then forward the CG and in the lower part, they have to copy the rounded shape of the fuse (customized pack). Or you can put the pack forward the fan’s hub inside a tube. If you have a glow engine, it will be over the CG and the fuel tank behind the engine (beware, to calculate the CG, in this case we have to consider the tank full, because it is behind the CG).
Anyway the accurate position of the power plant should be trimmed with the model in the hands.
Here are the figures for three different scales and the modified ones, all in meters.
Old May 17, 2003, 09:01 PM
nick_cool's Avatar
Joined Apr 2003
Here is the RC stuff over the plan.
As you can see my CAD is older than yours
Old May 19, 2003, 07:03 AM
nick_cool's Avatar
Joined Apr 2003
I will construct it all from scratch.
First I cut the wings and the fuse from white foam (20kg/m3) with a hot wire. To do this, I needed to build the airfoils and the fuse shape in balsa cover with ciano in order to admit the hot wiring. I have to admit that it is better to shape in aluminum that in balsa, particularly the airfoils. Regarding the foam, it was the best I could get.
Here are the 3 views of the model I used to cut the foam (hot-wire), the main modification made to this plans was the enlargement of fuse’s diameter, I need 92mm inside plus the RC equipment space.
Old May 20, 2003, 07:19 PM
nick_cool's Avatar
Joined Apr 2003
I covered the foam with pre-molded glass fiber + epoxy the wings. I pre-molded the fiber glass in a window glass. Summarizing, cut the fiber, covering the window glass with the epoxi and after that put the fiber. Wait until the epoxi gets no liquid and put the lamina over the foam which should wetted with epoxi.
Previously I practiced the same technique with the rudder. Very good idea!
Old May 20, 2003, 07:21 PM
nick_cool's Avatar
Joined Apr 2003
Here is a photo taken last sunday
Old May 22, 2003, 07:55 PM
nick_cool's Avatar
Joined Apr 2003
Another one
Old May 26, 2003, 07:14 PM
nick_cool's Avatar
Joined Apr 2003
Oh, oh!
I finished to cover with fibra a half wing, and after the cure, I realized is not ok.
I should leave the epoxi drying for more time next, the wing surface is waved.
Old May 27, 2003, 12:41 AM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
I dig it. I'd like to make that plane in a glass version. It's like a Mig 21 without the cone.
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old May 28, 2003, 06:27 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2015 , May 28-31
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
While going through my FS2002 aircraft list, look what I found.
Rotating
Kevin Cox is offline Find More Posts by Kevin Cox
Old May 28, 2003, 06:28 PM
Kevin Cox's Avatar
Joined Jan 1997
Gear going up
Old May 28, 2003, 06:30 PM
Kevin Cox's Avatar
Joined Jan 1997
It is time to buzz the tower
Old Jun 02, 2003, 08:29 PM
nick_cool's Avatar
Joined Apr 2003
Yesterday I finished to cover the second half wing. As the first was bad, this time a tried a different mix. I used 2 parts of epoxi for each part of fiber (48g/m2). This time I think it would be great, for this low weigh 1 to 1 proportion is too few epoxi.
I will try to take some photos for the next post.
Great landings!
PS thanks Kevin!
The Start of my YF-23 Black Widow II Project RCWorks Foamies (Kits) 39 Jul 14, 2009 07:24 PM
Sold any one want a Hornet II project? kramer Aircraft - Electric - Helis (FS/W) 3 Feb 12, 2007 06:42 PM
Help! Dart Kitten II project. figaro02 Scale Kit/Scratch Built 0 Mar 31, 2006 05:45 PM
Synergy II Project Seth Aircraft - Sailplanes (FS/W) 1 Apr 08, 2004 11:51 PM
