Old Jul 20, 2008, 09:26 AM
It's a spiderweb of knit lines
Souderton Pa. USA
Joined Mar 2002
Mini-HowTo
Brushless Vapor/Kyosho/Parkzone brick
Hi,
I'm starting this thread to keep track of working brushless bricks and the technical data on how to do it. Please post which brushless controllers work with the converters.
I used the converter designed by QUAX and sold by TheSteve here: http://thesteve.ca/walkera/ with a Cessna brick and a YGE4 brushless controller.
Hook up is as shown in the link with the yellow wire going to the FET gate as shown in the picture below.
I built my converter onto a female JST connector and soldered that onto the brick so my YGE just plugs in. Other mounting methods/hard wired should work just as well
Tested with one cell on the bench and in the air, works great. I have not tried 2 cells but I THINK the brick maybe ok at 5V BEC voltage, try at your own risk.
Edit: Note that you won't be able to program your ESC when it's attached to the converter/brick. You will need to have a normal rx to program the ESC.
mcross is offline Find More Posts by mcross
Old Jul 20, 2008, 10:57 AM
Corona, CA
Joined Sep 2007
This is very cool. I need to check it out.
Mr._Mulligan is offline Find More Posts by Mr._Mulligan
Old Jul 20, 2008, 11:41 AM
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
It should be mentioned that the brush to less converter designed by Quax has the entire project available down in the DIY section. You will need to make your own circuit boards, and be able to program the AVR, but for those that can, the info is there. (sorry Steve). Just wanted to make sure those that can do this know where to look for the info. Also note that Steve may have changed a couple of things with this adapter, so his version may indeed be better. He works with the AVR chips, so his knowledge base and resources extend pretty far.
Also for the price Steve is charging, it will be hard to justify the DIY route unless you really want to do it yourself. Yes you can make them for around the $15USD, but there is going to be a bunch of work to do. I think I am going to be lazy and just grab a couple from him when the Vapor bricks are in good supply, not worth my time to build it myself.
Now if we can only get a brushed to direct connection brushless controller (connect motor to adapter without another ESC), you could save that extra gram!
village_idiot is offline Find More Posts by village_idiot
Old Jul 20, 2008, 12:11 PM
Souderton Pa. USA
Joined Mar 2002
Thanks VI, I forgot to mention the DIY route. Here's the link http://www.rcgroups.com/forums/showthread.php?t=744929
There really isn't much to it so I doubt a board is really needed, in fact Steve does his without a board. For most people I think Steve's is probably the best way to go unless you already have a programer. $15USD is really the easy, quick way to go brushless.
Old Jul 20, 2008, 03:26 PM
Inciting Riots
Joined Dec 2006
Cheapest reliable programmer is the AVRDragon, and that will set you back about $40-$50. So he builds these dead bug style? Surprised he didn't build up a little circuit board with surface mount stuff. I'll have to look more closely at the schematic and see what I think my approach would be. Circuit boards just lend themselves to "mass" production.
Old Jul 20, 2008, 05:19 PM
Souderton Pa. USA
Joined Mar 2002
It's only 3 components and 4 wires. Steve does a very good dead bug with glue for strain relief and shrink covering for protection. End result is a very light assembly.
Old Jul 22, 2008, 10:16 PM
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
Subscribing
John
pmpjohn is offline Find More Posts by pmpjohn
Old Jul 22, 2008, 10:31 PM
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
That for posting this Mike. Even though I sell the converters I fully support and will still help anyone else that makes there own!
I've pondered going brushless in one of my Vapors. I was thinking of making an even smaller converter and using the new 1 gram esc. I think I can get the converter down to 0.1 grams(or less) and the brushless ESC is 0.42 grams with all wires removed.
Question is, what motor/gear/prop combo do we run?
TheSteve is offline Find More Posts by TheSteve
Old Jul 23, 2008, 05:25 PM
Souderton Pa. USA
Joined Mar 2002
wiring diagram
Hi,
I through this together to answer the question that's bound to come shortly.
Last edited by mcross; Aug 13, 2008 at 04:36 PM. Reason: added picture, added note to diagram
Old Jul 23, 2008, 09:09 PM
Inciting Riots
Joined Dec 2006
Steve,
What would it take to get a single AVR device that will read the brushed motor signal, and output the pulses for the brushless motor? After that all you would need are some FETs and a whole step could be skipped, along with the extra weight (not that is weighs much). Just a thought for a product that is still lacking.
Old Jul 23, 2008, 09:24 PM
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
Originally Posted by village_idiot
Steve,
That exists actually, its the SBL-Flea from Quax. There are two different software versions for the ESC. One is driven via regular receiver PWM. The second version will connect direct to the motor negative output of a 1S brushed ESC and use regular motor PWM to driven the brushless ESC. The PCB can be purchased from an online store in Germany. It uses an Atmel mega8l or mega88v. Assembled without any wires its about 1.2 grams.
Old Jul 23, 2008, 09:30 PM
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Nice idea building the converter into a connector!
Tim Wolff is offline Find More Posts by Tim Wolff
Old Jul 24, 2008, 11:37 AM
Corona, CA
Joined Sep 2007
This converter does not change the current limit of the FET, correct? So, if one were to combine Dan Schlarlach's mod to increase the current limit to 2A, with this mod, it should theoretically work? (emphasis on theoretical).
Old Jul 24, 2008, 12:33 PM
Inciting Riots
Joined Dec 2006
Hmmm.... That sounds like a better deal. Is there a thread on the SBL-Flea? I don't think I've seen it.
Old Jul 24, 2008, 12:44 PM
Dr John
pmpjohn's Avatar
Joined Dec 2001
It would be my understanding that with this mod the only current the original FET would be carrying is the signal. The brushless ESC would be carrying the motor load which would be limited only by the specs of this ESC.
John
Found Kyosho/Parkzone Centurion Brick 56S Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 May 28, 2008 02:39 PM
Discussion New Parkzone/Kyosho Rx Brick Bleriot Scratchbuilt Indoor and Micro Models 0 Mar 12, 2008 08:50 AM
Discussion Kyosho/Parkzone brick & Dumas Citabria 17.5"WP? 56S Scratchbuilt Indoor and Micro Models 8 Aug 27, 2007 12:15 PM
Discussion Suggestions for cheapo brushless for Parkzone Focke Wulf Microangelo Power Systems 2 Aug 17, 2006 08:16 PM
Sold Brushless Kyosho Learjet/Ducted Fans & ESC HARRomeo Aircraft - Electric - Airplanes (FS/W) 14 Jul 12, 2005 06:45 PM
