Old Oct 12, 2002, 08:30 AM
too old to 3d
Scott C's Avatar
United States, GA, Peachtree City
Joined Aug 2000
DC Hobby's Allure -- Good conversion candidate?
Good balsa 2 meter ship kits with ailerons are hard to find. I was eyeing this kit as an electric conversion with a light direct drive brushless motor and 8 1300 CPS. Any thoughts?
http://www.dchobby.com/thermal/allure.html
Scott C is offline Find More Posts by Scott C
Old Oct 12, 2002, 11:13 PM
Wilkes-Barre/Scranton, Pennsylvania, United States
Joined Nov 2000
Scott
After doing several conversions I have learned to check the following:
Make certain the motor you intend to use will fit in the nose of the plane. It is a lot easier to make adjustments now than after the fuse is built.
Same for the battery. Will all the equipment fit in the space available. You will be adding a battery pack,an ESC and a motor. These are items that were not in the original design and so they must be compensated for. Place these items carefully. It will make balancing easier later on.
if using ailerons use a servo in each wing. Two reasons for this-more positive control due to shorter linkages and it allows the wing center section to be free of the aileron servo. You will most likely need all the room you can get in that area.
BillM is offline Find More Posts by BillM
Discussion E-Hobby RC Brushless motors and ESC's any good? TheDustyPagan Power Systems 7 Apr 03, 2007 11:10 PM
Discussion Hobby Lobby's Glow to Electric conversion "Helper Service" JAM Glow to Electric Conversions 14 Apr 05, 2006 04:10 PM
cp1700's looking good! p471701 Electric Ducted Fan Jet Talk 4 Jul 27, 2001 11:52 AM
Watt Age esc's, No good? Or just mine? slowflyer Electric Plane Talk 9 May 29, 2001 08:38 PM
EDF's From Germany & Conversion Rates AndrewK Electric Ducted Fan Jet Talk 23 May 22, 2001 01:31 PM
