Old Oct 12, 2014, 02:33 PM
United States, MN, Merrifield
Joined Sep 2013
why 7 channel raido for 600 and up helys
what is the 7 channel for and can you use 6 channal raido
and will a bent mainshaft cause gyro to oslate side to side in flight
rodney m is offline Find More Posts by rodney m
Old Oct 12, 2014, 06:42 PM
I win again!! - mother gravity
Flying Pitcher's Avatar
Greenland, Qaasuitsup
Joined Apr 2013
probably for nitro or gas to engage or disengage clutch. google it!
Flying Pitcher is offline Find More Posts by Flying Pitcher
Old Oct 12, 2014, 07:11 PM
Happiness is a belt fed weapon
Cleared2Engage's Avatar
Ventura, CA
Joined Oct 2009
Was for governors and such. You can use a 6 ch on just about any cp electric. Should also add that if youre using a fbl controller like the Naza H youre going to need 7 channels.
Cleared2Engage is offline Find More Posts by Cleared2Engage
Old Oct 12, 2014, 10:40 PM
Denver, CO
Joined Dec 2005
Almost all RC helicopter clutches are centrifugal. So automatic, not controlled by the transmitter.
The reason more channels are required, is when the electronics you chose require it. You can get most things in a model that does not need a channel. For example you can buy tail gyro's, governors, and flybarless controllers that do not need a channel. However without dedicating a channel you will lose remote adjustment options.
Additional channels also give you more possibilities, and options. Usually the transmitters with more channels also include many more features.
Roto Rob is online now Find More Posts by Roto Rob
Old Oct 13, 2014, 04:44 AM
Letchworth, Great Britain (UK)
Joined Jul 2004
As others have said, 6 channels is usually plenty for an electric heli. Extra channels may be necessary if you want remote adjustment of your flight settings (if your flight controller supports that), or extras like retracts, switchable lights, etc.
A bent mainshaft can cause all sorts of problems, including vibration that'll disrupt your gyro's operation If you know it's bent, replace it; if you think it's bent, take it out and roll it on a flat piece of glass to check. Vibration can also be caused by other things like out of balance blades (main or tail), worn bearings, worn linkages, etc. First simple check is to take the blades off and then see if there's any vibration when you spool up.
abenn is offline Find More Posts by abenn
Old Oct 13, 2014, 07:35 AM
Joined Apr 2013
RotoRob, cool info on clutches. never knew that
Old Oct 13, 2014, 09:56 AM
holtneil's Avatar
United Kingdom, England, Central Bedfordshire
Joined Dec 2012
Hi mate i had a tail shake on spin up and down didnt know what it was , turned out to be a bent main shaft , so this is what it did to mine
Align 500 pro tail shake (1 min 13 sec)
holtneil is offline Find More Posts by holtneil
Old Oct 13, 2014, 10:21 AM
Joined Apr 2013
wow, it did jump around a little, when did you bend it, sir?
Old Oct 13, 2014, 03:13 PM
Joined Sep 2013
dose it in forward flight main head causes a rocking side to side in a hover
it gone. got a dfc head coming this week carbin blades to i will let you know
if i get thing strated out
For Sale Trade my tablet for your electronics (600/700 size heli) Whopper Chopper Non R/C Items (FS/W) 3 Yesterday 08:23 PM
Discussion WHY are people putting For Sale ads up without Pic's Magoo76 Trader Talk 50 Oct 13, 2014 11:27 PM
Sold KDE Main Gear Assembly for T-Rex 550/600 helis curmudgeon Aircraft - Electric - Helis (FS/W) 0 Sep 30, 2014 06:30 PM
Discussion Setting up 4 channel TX for 3 channel plane HeliDrew Beginner Training Area (Aircraft-Electric) 4 Sep 27, 2014 07:08 PM
eclipse 7 ---what's up with channel 5 in heli mode?? BIFFSTER Hitec/Multiplex USA 0 Nov 22, 2003 05:23 PM
