Old Feb 03, 2013, 10:22 PM
Joined Nov 2012
R/C - Autopilot Switch
I am building a switch that allows servo control to be switched between a 4 channel R/C and autopilot using a spare R/C channel. It will be used for flight testing the autopilot whilst being able to take control if something goes wrong. I was wondering if this would have any general interest? It uses an Atmel uC to measure the pulse width and a TI video switch to route the signals. The current schema is to have the number of valid control pulses programmable so noise does not make it switch. Drop out of the R/C signal would switch to autopilot. This could be used to hand off control to another transmitter.
magno_grail is offline Find More Posts by magno_grail
Old Feb 04, 2013, 01:00 AM
Chris Anderson
San Francisco/Bay Area
Joined Mar 2007
There are already quite a few products that do this on the market. Here's one, which has been around for years and works well:
http://store.diydrones.com/product_p/br-0001-10.htm
zlite is offline Find More Posts by zlite
Old Feb 04, 2013, 10:22 AM
Joined Nov 2012
Yes, that is essentially the same. I wonder why they made it so big? If they used a TSSOP package and put parts on both sides of the board they could have shrunk it quite a bit. That is what I did with my video switch:
Old Feb 05, 2013, 06:01 PM
Joined Nov 2012
Noticed a hardware problem with the diydrone mux. It only allows one control signal for switching the servo signals. At least for my application, the autopilot needs to normally switch the servo signals because the integrators have to be zeroed before switching. In case of an emergency or the ground controller hanging up the R/C system has to be able to regain control.
A software problem is it allows the control to switch whilst a servo signal is active. It should wait until the current signal is finished then wait until the new controller is inactive before allowing the signals through. For that the uC needs to control the gate line of the 74HC157.
Discussion OcCre Mississippi R/C Steam Conversion SteamSurge Steam Boats 15 Jan 28, 2013 01:43 AM
Question DX8 setup for 1 switch D/R ??? G-Man Radios 3 Jan 13, 2013 10:51 PM
Sold Zenoah G-62 r/c ignitions conversion $200 shipped sagomon Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 05, 2013 10:06 AM
Sold *NIB* .40 R/C ABC Engine w/Muffler..Tower Hobbies..$44.73 SHIPPED2U! bighank13 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jan 04, 2013 05:01 PM
Swap Meet ** LCRC R/C Swap Shop Newark, Ohio Feb.2nd ** Sammy70 Electric Flight Events 0 Jan 03, 2013 09:35 PM
