Closed Thread
Old Nov 23, 2012, 12:02 PM
DragonLINK UHF only!!!!
Joined Feb 2011
Question
Step Down Regulator and LC-Filter All in ONE?
Just wanted to know,
Is there a StepDown Regulator with Built in LC filter?
I want to use "one Lipo setup"....
I have 4s-5000mah Flight Lip and want to power RC and 12v VidTx/12v Camera.
I'll use the ESC power leads to tap the 16volt from the 4s Lipo....
LexusFPV is offline Find More Posts by LexusFPV
Old Nov 23, 2012, 01:39 PM
Push'n the limits
NutBag's Avatar
Australia, QLD, Brisbane
Joined Oct 2005
Baa Baa Blacksheep do their Core... Works great for me
NutBag is offline Find More Posts by NutBag
Old Nov 23, 2012, 01:45 PM
Joined Feb 2011
ok thanks NutBag....
I also wanted to know, if I do get two separate LC filter and 12 step Down regulator,
can I line them up (solder in parallel) one after the other? the ESC connector will
have these two plus I'm tapping that ESC connector with the CC BEC.
So 3 items soldered (tap) onto the ESC power wire....is that a lot?
Old Nov 24, 2012, 03:36 AM
France, Bourgogne, Nevers
Joined Feb 2012
There ought to be a good, rf-quiet filter, sepic type power supply (up-down) with L-C, but there is not.
The whole point is to take the power off the battery direct.
For each power supply, wire the power supply off a power tap, like the Dean plug tap. The L-C filter is wired from the power supply output, downstream of the power supply. The load goes next, off the "out" terminals of the L-C. So actually there's only the power supply(s) directly off the tap.
My 12v. load, on a full-house Eagle tree setup and 3s pack, is 0.9 amp, with four sensors, 1000 Mw lawmate tx and a 600 tvl camera.
Add up yours, then add a safety margin.
wazoo22 is offline Find More Posts by wazoo22
Old Nov 24, 2012, 06:03 AM
DESH BOUKSANI's Avatar
McClean, VA
Joined Dec 2010
Got a diagram?
DESH BOUKSANI is offline Find More Posts by DESH BOUKSANI
Old Nov 24, 2012, 11:44 AM
BEOWULF
North vancouver, B.C. Canada
Joined Apr 2008
Range video sells linear regulator that works great with step down from 4 cell battery
No need for filter and only cost 10 $
Heat sink and proper cooling is good
Amp draw should be within specs
Correct antenna will bring down amp draw and make video best
Antenna best at tuned frequency to work and function best
This alows for lowest amp usage but also clearest video
Draw or take video power from balance lead rather from other wires for good video
David22 is offline Find More Posts by David22
Old Nov 24, 2012, 12:29 PM
Joined Feb 2011
Thanks David22 for your input.
I will take the power off the 4s Lipo "balance leads", but the connectors seems flimsy.
(do you have a LINK on were to get those connectors?).
Also, the once I use the RangeVideo Step Down Regulator,...I won't need a LC-filter
because it already has great filters in it?.... Thank You....
http://www.rangevideo.com/index.php?...roducts_id=161
~15ve In and 12ve out? how come there is 3 pins for Output?
Old Nov 24, 2012, 12:42 PM
radicalron's Avatar
Palmdale, CA
Joined Sep 2008
The Core from TBS. Have 2 of them work awesome. You do need soldering skills
radicalron is offline Find More Posts by radicalron
Old Nov 24, 2012, 12:49 PM
Joined Feb 2011
Can I disable that OSD function on it?
What was the point of the CORE? to have "Regulator" and very basic OSD screen
for ~$80 without shipping
Range Video Step Up Regulator ~$10
HobbyKing SimpleOSD ~$15
Same function as the CORE?
Old Nov 24, 2012, 01:44 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yes built in OSD can be disabled or ignored.
for ~$80 without shipping?
No. Perhaps you should read the description again. It's not just a step up (or just step down)
regulator. It's an any2any, and it has two outputs, each with their own selectable voltage.
It also has a failover to backup battery in case the main pack is drawn down dead, offering
true dual redundancy rather than the more usual two single points of failure
that people create when they use one battery for power system, and another for FPV side.
ian
Daemon is offline Find More Posts by Daemon
Old Nov 24, 2012, 01:51 PM
Joined Feb 2011
Ok, I see....but How is that CORE connected/tapped onto the ESC power wires (4s Lipo)?
It just shows' the CORE is inbetween the Camera and VidTx?
So, if I connect the VidTx power wires to the ESC (tap) connector, it will filter out the noise to the camera?
Old Nov 24, 2012, 01:55 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
That's up to you. Most folks add (solder in) a couple wires behind their main power plug.
I always put a female servo connector on those, and my FPV harness starts with a male
servo plug and the wires from that head into my voltage regulator.
ian
Old Nov 24, 2012, 11:25 PM
BEOWULF
Joined Apr 2008
If you use 4 cell battery you only need step down
Step up and down regulator is good for 3 cell main battery
Old Nov 25, 2012, 12:18 PM
Joined Feb 2011
David22,
ok, I will just get that Step Down Regulator from RangeVideo....
I'm using 4s flight lipo (one battery setup)...simple!
Old Nov 25, 2012, 01:35 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Just know that with a linear regulator, you're throwing away the difference in voltage
as heat. So if your FPV gear draws say.. 750mA * 12V = 9W, then the regulator is generating
roughly 3W of heat.
BTW, the reason an any2any regulator is useful for the TBS Core is that you don't have
to use the same type of battery for the backup. Flight pack can be 4S, and the backup
battery a little 2S and it'll still deliver rated voltage on all outputs.
ian
Closed Thread
Sold 2 Align RCE-B6X Voltage Regulators new! w/step downs HD Hucker Aircraft - Electric - Helis (FS/W) 2 Sep 01, 2014 08:50 AM
Help! Introduction of a regulator and LC filter BriGuy82 FPV Talk 23 Dec 04, 2012 07:25 AM
Sold Align RCE-B3X External BEC With 5.1V Step-Down Voltage Regulator nitrodude71 Aircraft - Electric - Helis (FS/W) 3 Nov 19, 2012 09:20 AM
Sold Align RCE-B3X External BEC With 5.1V Step-Down Voltage Regulator nitrodude71 Aircraft - Electric - Power Systems (FS/W) 3 Nov 19, 2012 09:18 AM
Sold ALIGN 6A External BEC w/ 5.1V Two-way Step-down voltage regulator K10382A helifreak592 Aircraft - Electric - Helis (FS/W) 0 Feb 24, 2012 03:57 PM
