Old May 24, 2012, 11:10 AM
James not bond
jy0933's Avatar
Joined May 2012
Help!
battery connector
hey folks....
I got 2 Turnigy 5000mAh 3S 40C Lipo Pack
then here comes the problem.. I cannot find a suitable connector... I want to wire 2 connectors to the power distribution board so that I can connect the battery directly, with out a dean adapter.
the spec on the HK says it needs 5.5mm bullet connector... but what I can find all around are all 3.5mm or 5mm... there just seems not 5.5 around.
what should I go for to get this done?
can some1 help me out on this..
jy0933 is offline Find More Posts by jy0933
Old May 24, 2012, 11:24 AM
God of Gravity Poisoning
Arkansas Travelr's Avatar
Joined Nov 2010
Go with 6mm bullets
http://www.xtremepowersystems.net/pr...prod=XPS-6mm-1
Arkansas Travelr is offline Find More Posts by Arkansas Travelr
Old May 24, 2012, 11:35 AM
James not bond
jy0933's Avatar
Joined May 2012
thank you
btw...for the wire... what awg should i go for... the thicker the better?
Old May 24, 2012, 11:54 AM
United States, MN
Joined Feb 2011
Looks like battery probably has 10 or 12 AWG on it. What you "need" depends on how many amps you plan on pulling. Also look at the related items on the battery page, here's the connectors:
http://www.hobbyking.com/hobbyking/s...idProduct=9763
Here's a charge lead which has 14AWG wire on it:
http://www.hobbyking.com/hobbyking/s...dProduct=18098
grimbeaver is offline Find More Posts by grimbeaver
Old May 24, 2012, 12:06 PM
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
That battery comes with 10ga wire.
Rick
rampman is offline Find More Posts by rampman
Old May 24, 2012, 12:32 PM
James not bond
jy0933's Avatar
Joined May 2012
is it a good idea to cut that banana connector out and solder the wire onto the power distribution board?
Old May 24, 2012, 12:44 PM
United States, MN
Joined Feb 2011
That would be an option if you wanted to do minimal soldering. However as I said it's only 14 gauge wire. Since you have not said what your application is, such as how many amps or what kind of power distribution board you are connecting to we can't tell you if that is sufficient.
Old May 24, 2012, 01:41 PM
James not bond
jy0933's Avatar
Joined May 2012
expecting around 80A top.. (using 4*20A esc but wont go that much tho)
got 2 kind of distribution board... http://www.hobbyking.com/hobbyking/s...dProduct=23140
and the one like this
Old May 24, 2012, 01:53 PM
United States, MN
Joined Feb 2011
You'll need at least 12awg wire, 14awg is too small for 80A. You said you have those two batteries now, I would use connectors based on what you plan on buying for batteries in the future. The nanotech and gens ace come with HXT4mm and those connectors are easily found from many vendors and though at the top of the range should handle 80A. If you think you will always buy the regular Turnigy then order the 5.5mm it uses. I don't know about you but I don't like replacing my battery connectors all the time.
Old May 24, 2012, 05:12 PM
James not bond
jy0933's Avatar
Joined May 2012
I will probably stick with those 2 big junk for a while.... so probably I should stick with the same size plug so it is easy to replace.....
I heard about people using dean on power board side and use different size adapter for battery... But wont that be bad practice cuz the adapter might be a bottle neck/weak point?
Old May 25, 2012, 07:27 AM
United States, MN
Joined Feb 2011
Every connection adds resistance / waste in the line. To some people getting every bit of power out is really important.
I imagine Deans would work, but pulling that much power I would use the real thing as most of the knock offs are only rated 60-70 amps.
1 New and 1 Used XT60 Battery Connector Dave8888 Non R/C Items (FS/W) 3 Mar 14, 2012 12:02 AM
Used XT60 Battery Connector Dave8888 Non R/C Items (FS/W) 1 Mar 04, 2012 07:45 AM
Discussion Battery Connectors Fatherof4 F3A Pattern 15 Feb 27, 2012 08:13 PM
For Sale $6 for 2 Pairs of EC5 Battery Connectors: 2 Device & 2 Battery Connectors maverickma Aircraft - General - Miscellaneous (FS/W) 0 Dec 08, 2011 11:31 AM
