Old Mar 10, 2012, 06:19 PM
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Build Log
7" Zipper: 24mm
So here it is: my intended speed entry. I'm only a couple months late.
Specs:
Wingspan - 6.89" (175mm)
Length (without vert. stabs) - 11.42" (290mm)
Intended Components:
Receiver - Rx33
Servos - AS2000LBB (with diodes)
ESC - Plush 6a Lightened
Motor - 1015 11500kv
Fan - My own NDF24 with rotor
Battery - Anything but Nanotechs
The shape is an original ogival design that I came up with during the creation of the Chimera. (I was one of the original designers. ) I made it with a layer of white cellfoam (bottom) and a layer of grey depron (top), both of which are 3mm giving a total thickness of 6mm. I am going to round the leading edges and taper the trailing edge.
Now here is where I would appreciate some advice. It is still in the folded state. The two halves are only attached by the skin of the grey depron. When I drop it grey side down, it has a slight dihedral which lets it float down flat. Now when I drop it white side down, it has a slight anhedral which makes it ridiculously unstable.
I definitely would not give it anhedral, but what about giving it a slight dihedral? I don't plan on flying inverted. Heck I barely plan on flying the thing.
I trimmed the wing edges to the way they are supposed to be. The wing weighs 6.45g so far.
Yes it will have a fuse.
Kev
boredom.is.me is offline Find More Posts by boredom.is.me
Latest blog entry: RFD900 Case
Old Mar 10, 2012, 11:47 PM
Joined Nov 2007
I still haven't glued the seam, cut the elevons, or sand the LEs.
Old Mar 11, 2012, 03:04 AM
Joined Nov 2007
Old Mar 11, 2012, 06:29 AM
Fear me, I'm a space-duck.
hanzie's Avatar
Nederland, GE, Wageningen
Joined Nov 2011
Ha, nice! That plane looks a lot like the plane I'm thinking of to build next.
Now I know the design has been done before, I'm sure I'll be able to get one to fly too.
hanzie is offline Find More Posts by hanzie
Old Mar 11, 2012, 11:25 AM
Effumall
kelberts's Avatar
Joined Nov 2005
Reminds me of the "Rayfish" and the "Shuttlefish" Metroidrc and I did several years ago.
http://www.rcgroups.com/forums/showt...hlight=rayfish
Flew pretty well.
Flat airfoil worked fine. You might want to consider a thrust tube and some intake fairing for the motor, to help with thrust and drag.
Also, we found that if you fair the edges of the EDF cutout, that helps with the airflow.
kelberts is offline Find More Posts by kelberts
Old Mar 11, 2012, 11:37 AM
Joined Nov 2007
I have a much thicker leading edge when comparing the size of the planes though.
Definitely. I'm still waiting on the fan though.
Already started.
Old Mar 11, 2012, 05:29 PM
Effumall
kelberts's Avatar
Joined Nov 2005
This thing is the same idea. It was a 40mm deal, and was very fast...
Old Mar 11, 2012, 05:43 PM
Joined Nov 2007
Kool, what was your auw? I'm trying to stay below 40g, but then again mine is much smaller. I wonder if 50mph is feasible? My objective is to keep up with my friend's stryker which does about 50 or so level.
Old Mar 11, 2012, 06:11 PM
Joined Nov 2007
The elevons have been cut, but I forgot to bevel the trailing edges before I put the control horns in. They are a little small so I am worried about slow speed handling. What do you guys think?
I started rounding the top. I might just leave the bottom straight.
The underside will receive a black "fuse" plate along with either one large fin or two smaller and longer fins. I'm worried about sliding.
I must say, this is probably the sleekest model I have ever conceived.
Old Mar 12, 2012, 07:54 AM
Effumall
kelberts's Avatar
Joined Nov 2005
I think the AUW of the "Mirage" was maybe 60-70 grams? Again, it was a 40mm fan with a Feigo inrunner on 3S. Used Bluebird servos. If I redid it, I'd make it 30mm, and use PZ micro linear servos. The problem is with a high wing loading and not much span, it wants to roll like mad.
I bet you'll easily do 50MPH, if you can keep it stable.
BTW, is your fan going to sit on top, or will it be halfway down? If it's down in the middle, you'll probably want more area in the intake cutout. I experimented with a "NACA" shape, but ultimately found a "U" shape worked best.
Old Mar 12, 2012, 08:56 AM
Effumall
kelberts's Avatar
Joined Nov 2005
And this one was a 55mm thing. It was a floater.
Old Mar 12, 2012, 09:21 AM
Joined Nov 2007
It is going to sitting on top.
Old Mar 12, 2012, 10:23 AM
I'm BIG on micros
Canada, ON, Brampton
Joined Mar 2011
JSS4 is offline Find More Posts by JSS4
Old Mar 12, 2012, 10:45 AM
Joined Nov 2007
Old Mar 12, 2012, 11:22 AM
I'm BIG on micros
Joined Mar 2011
Thanks. Things make sense now.
Build Log Boulton P111 "Part 2" 24mm fan MaHö Micro EDF Jets and Power Systems 107 Jun 04, 2012 02:22 AM
Sold RTF Birdworks 48" Zipper (BPV) Dave Reese Aircraft - Sailplanes (FS/W) 2 Mar 09, 2012 11:06 AM
For Sale Himax 24mm x 24mm 4100kv ($25 shipped) RC_Bob Aircraft - Electric - Jets (FS/W) 0 Dec 14, 2011 10:47 PM
Sold 7- 24mm cdrom motors for brushless conversion the_only_kris_20 Aircraft - Electric - Power Systems (FS/W) 4 Jul 01, 2008 11:47 AM
