Old Jan 31, 2012, 10:43 PM
kayvannouri's Avatar
United States, TX, Dallas
Joined Aug 2011
Idea
FUNJET, what is the fastest setup possible ???
What is the fasted motor and ESC that I can run on 4s, 5s, 6s batteries ?
I want firm and specific motors and ESCs and possibly links to the motors ?
I wanna go beyond 160mph
kayvannouri is offline Find More Posts by kayvannouri
Old Feb 01, 2012, 12:13 AM
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Län, Ljungby
Joined Jan 2001
The kero burner is hard to beat speaking performance, lands like a 4S setup and has the speed of a 8S setup However most find it a bit pricey and it's not what asked for here, still I think it's worth to look at.
henke is offline Find More Posts by henke
Old Feb 01, 2012, 01:09 AM
Sure it'll work
Flyextreme's Avatar
United States, CA, Torrance
Joined Nov 2005
You could try this
Funjet with Kolibri turbine (4 min 8 sec)
Flyextreme is offline Find More Posts by Flyextreme
Old Feb 01, 2012, 06:43 AM
The Sarawak KoloMee
SniperWj's Avatar
Singapore
i know im ot.
but funjet ultra+turbine=quality speed! a 2s 1000mah is what we need to fly the fj
x2 the speed you want.
Yiming
SniperWj is offline Find More Posts by SniperWj
Old Feb 01, 2012, 01:13 PM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Well, to go beyond 160mph, you dont need anything special, its easy with a descent 5s setup,, like a Mega motor or even a Typhoon motor..
Fastest? well thats a hard one, but if you want FAST on 6s lipo ? you have to go 36mm motor, a big one, bigger propps like 6.5 or 7", maybee like 150-200 amps on 6s will take you very far IF the motor, battery and esc can take it..
I am right about starting building my second Ultra with 6s and this motor:
http://www.hobbyking.com/hobbyking/s...dProduct=19110
And a cheep KH 190/200A esc
I think it will take my pretty high in speed... and cheep
But your question is the FASTEST ? dont think anyone could say what the fastest is, when the speed starts to get near 190-200mph I think its very important to finetune the funjet to get is stable, even if the setup can push the plane at those speeds, you still have tuning to do to be able to fly that fast..
180mph, you can do, pretty cheap also, but 200mph(real speed), naaa, to much to lose to get that extra speed..
sebbe is offline Find More Posts by sebbe
Old Feb 01, 2012, 01:35 PM
henke's Avatar
Joined Jan 2001
the last couple of mph always cost alot
Old Feb 01, 2012, 03:11 PM
Joined Aug 2011
Great information guys, so by fastest I probably meant about 180 MPH, that should be enough for me without going into those turbine. I currently have Turnigy 3648 1450KV on a 5s setup and I think I hit above 140 MPH, no radar gun yet !
Old Feb 01, 2012, 03:20 PM
186mph Funjet Ultra
E-speed buff's Avatar
nieuw vennep, the netherlands
Joined Feb 2010
What prop are you using? With a 7x6APC sport and throttle control and some fine tuning I have already flown >160 on 6S.
The problem with cheap systhems is the weight.
The heavyer the funjet, the harder it will be to launch it.
I use an expensive but light motor and esc just for easy launching.
With a Kontronik minipyro on 6S and a 7x8APC sport I reached 186mph average in horizontal flight.
Static current ~150A! This is borderline for the 2650 45C batt's.
Grtz Rene
E-speed buff is offline Find More Posts by E-speed buff
Old Feb 02, 2012, 12:43 AM
henke's Avatar
Joined Jan 2001
If doing some calculations from known numbers you get that 180mph needs about 2500watts input. 190mph needs about 3200watts
Old Feb 03, 2012, 04:03 PM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Seems 2200 watts will go 200mph.
FunJet 325kmh (1 min 54 sec)
same measure method as yours Baiojet Henke..
Old Feb 03, 2012, 07:00 PM
186mph Funjet Ultra
Joined Feb 2010
325km/h? With a 6x6 prop, no way!
The prop tips should have been supersonic at that speed! Especially with these low temp's.
It was not nearly loud anough!
Grtz René
Old Feb 07, 2012, 06:53 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Well, its not my funjet, the guy measured with his equipment..
There is another guy here:
Funjet Ultra 349 Km/h GPS ! for 300 $ (5 min 6 sec)
(this video is the first setup he did try, only 300km/h)
Later he is claiming 323km/h with a 6x6 propp, and 349km/h with a 6.6x6.5 propp
more info:
http://www.dauch.fr/
klick on the link : Reportage: Funket Ultra Multiplex
One did measure with pitot tube the other with GPS..
Old May 02, 2012, 11:24 AM
Joined Aug 2011
Turnigy SK3 Fandrive - 3659-1900kv (90mm EDF)
I am looking into Turnigy SK3 Fandrive - 3659-1900kv, so how was your experience with this motor ? how fast could you go with with size prop ?
it would be great if you can tell me how many amps and watts
thanks
Discussion Fastest Neu setup for a 4S Microjet johnnyrocco123 Power Systems 3 Jun 26, 2011 11:13 PM
Discussion What's the fastest foam plane? Is 200MPH possible? Fidy$Trainer High Performance 21 May 12, 2009 07:39 AM
what's the fastest setup for speed dives? kewhite Electric Sailplanes 4 Aug 12, 2004 06:37 AM
All Out Fastest Smart Setup Possible earnest High Performance 2 Mar 06, 2003 03:51 PM
