Old Oct 10, 2014, 07:27 PM
Joined Jun 2012
Build Log
Electric DLG conversion.
Description: Name: ImageUploadedByTapatalk1412983056.819810.jpg
Description:
Hi guys,
I've got an old Neos DLG that I've had lying around for quite a while now collecting dust. Don't live in the best location for DLG anymore, however I still wanna get it back up in the air. I want to attempt an electric conversion of this.
Such a wealth of knowledge on this forum, so though I'd try and pick all your brains for a bit before I started!
As you can see from the pictures the nose shape is pretty flat, was wondering if I could get some opinions from you guys on the best way to get a motor in there?
I was thinking maybe chopping part of the nose off and "attempting to mould a new one. Or Frankenstein a motor in their somehow and then create a small carbon shroud for aerodynamic purposes.
I'm thinking of using a emax CF822 out runner motor ( or the hobbyking equivalent FC 28-22)
Any tips or info would be greatly appreciated!
Alex
ahunter852 is offline Find More Posts by ahunter852
Old Oct 11, 2014, 01:06 AM
United States, MI, Macomb
Joined Nov 2003
ahunter, You might want to read is thread they use a small pod with a 11mm motor and 3x3 prop, I believe it would be easier to balance this way, A motor in the nose? You would have to cut the nose back quite a-bit on that fuse to get it to balance, And you don't have much their to start with your canopy is right there. http://www.rcgroups.com/forums/showt...r#post24762249
pecor is offline Find More Posts by pecor
Old Oct 11, 2014, 02:50 AM
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
Aero-Model has the perfect thing for that.
A10-7L Glider/Sailplane Motor w/ 4.4 GearBox
carlsoti is offline Find More Posts by carlsoti
Old Oct 11, 2014, 08:03 AM
Akerman's Avatar
Japan, Tokyo, Setagaya
Joined Jan 2005
I'm about to install one of these little Hackers in my Q12 (Horejsi) 2m F5J ship. Have seen it it in my friend's Q12x, it almost gets lost in the nose, but is very powerful. Swings a 13x8 on 3s. I will try a 13x10 and measure in-flight amps...
It is so light that I thought they forgot to put the motor in when I picked up the little Hacker box it came in...
Philipp
Edit: Might be difficult to get such a small spinner for your nose!
Akerman is offline Find More Posts by Akerman
Old Oct 11, 2014, 03:56 PM
Splash down counter: 10
xStatiCa's Avatar
United States, FL, New Port Richey
Joined Jul 2006
Another good thread that about power pods I am reading about too. http://www.rcgroups.com/forums/showthread.php?t=754627
xStatiCa is offline Find More Posts by xStatiCa
Old Oct 11, 2014, 07:47 PM
Now fortified with carbon
DLGjunkyard's Avatar
Canada, ON, Cambridge
Joined Apr 2010
Put a small inline Hacker in a DLG a while back. https://www.aero-model.com/8_74_1936...0-15L-4-1.html
Motor is for sale if you are interested [yes, shameless plug , I know]
DLGjunkyard is offline Find More Posts by DLGjunkyard
Discussion super mini Topsky DLG vs Dream Flight Libelle Dlg DavesterT Hand Launch 13 Sep 27, 2014 10:02 AM
Discussion Libelle DLG --> to Electric Sailplane Conversion ChinoDiablo Electric Sailplanes 49 Jul 28, 2014 05:00 PM
Wanted WANTED Electric sailplane / Maybe a trade/w a DLG im55scott Aircraft - Sailplanes (FS/W) 8 May 28, 2014 10:25 PM
Sold Convering - 12 rolls unopened edbu1 Aircraft - General - Miscellaneous (FS/W) 1 Apr 06, 2014 11:27 AM
Build Log Electric DLG TimR74 Electric Sailplanes 38 Mar 04, 2014 05:55 PM
