Old Sep 28, 2014, 05:51 AM
Essex BOF's Avatar
Joined Sep 2009
2 Metre Project 2015
I like to have a project to build over the winter period, so have decided to make a 2 Metre model to replace my lash up version of the Watts Up. Although it flew well for what it was, the landing was always problematical due to not having crow braking.
So drawn up new design loosely based on the Watts New that I have campaigned this year with good success.
It has an all flying tail plane this time, driven by a servo in the fin as is the rudder, will post more pictures as we go.
Essex BOF is offline Find More Posts by Essex BOF
Old Nov 01, 2014, 03:59 PM
Essex BOF's Avatar
Joined Sep 2009
Some pictures of the wing build, slowed down due to other things getting in the way.
Old Nov 16, 2014, 12:14 PM
Essex BOF's Avatar
Joined Sep 2009
Main wing panels sheeted, some pictures of the TE before & after sanding.
Old Dec 06, 2014, 03:58 PM
Essex BOF's Avatar
Joined Sep 2009
A few more pictures of the build, which is progressing slowly due to distractions of various types, which seem to be more when you are retired :?
It does take a bit longer as I get over problems as I go along, which when you are building something from scratch can be tricky. The wing is nearly finished so am building the fuselage to try and get the length of boom right, so as to be able to move the battery about to get the CG right, or somewhere near.
Old Dec 09, 2014, 07:37 PM
MMR
Martian
Joined Mar 2007
Great build!
I was looking at the tail configuration and the elevator servo arrangement is new to me. Could you provide a bit more detail? My scratch built 2M lost its elevator in flight due to under-engineering (actually I used a DLG mount I had). The wing survived just fine and I really want to build a new fuse.
Martin
MMR is online now Find More Posts by MMR
Old Dec 10, 2014, 11:22 AM
.: Looking for Thermals :.
Ricardo RW's Avatar
Chile, Quinta Región de Valparaíso, Los Andes
Joined Jun 2002
Yeah, I agree with Martin, and please consider telling us more about the sailplane it self:
* Airfoil
* Wing area
* Power plant
* Prop
* Target final weight
* Which controls are you planning to have: flaps? ailerons? spoilers?
* Fuse: it seems to be a pod-n-boom configuration, and it seems to that the tail feathers have an airfoil, which one?
Happy building.
Ricardo RW is offline Find More Posts by Ricardo RW
Old Dec 10, 2014, 01:20 PM
Essex BOF's Avatar
Joined Sep 2009
* Airfoil
* Wing area
* Power plant
* Prop
Happy building.
The elevator control is an experiment that I dreamed up to operate the all moving tail without using a pushrod & bell crank drive.
Thought the picture's would be self explanatory, but here goes:-
The servo has an extended 2mm dia rod on the servo arm, that engages into a ball link helicopter link, mounted on the pivot line of the tail plane. The tail plane moves up & down via this with the ball link allowing for the changes in position relative to the servo arm.
Airfoil is my version of MH30 as used on the Watts New, see blog.
Wing area, not sure but think it will be enough 596 square inches
Powerplant ,Hyperion 2218-10
Prop 10X6 or 9X8
Target weight:- 900grams max
Controls are full house Flaps, ailerons, elevator, rudder & motor
Tail airfoil HT14
Old Dec 10, 2014, 01:24 PM
Essex BOF's Avatar
Joined Sep 2009
Originally Posted by MMR View Post
Great build!
Martin
Have a look at the Watts Up blog as to mounting the tail plane which might solve your problem http://www.rcgroups.com/forums/showthread.php?t=1108935
Old Dec 10, 2014, 02:34 PM
Ricardo RW's Avatar
Joined Jun 2002
Hey... Thanks!!
Old Dec 10, 2014, 04:09 PM
MMR
Martian
Joined Mar 2007
Thanks as well - so the heli ball link translates the lateral movement into a rotation - hence mounting it on the pivot line (aerodynamic center) Will the servo usage enough torque and holding power? Look forward to flight reports & assessment.
I really prefer the all moving tail on my scratch building efforts as it males it easier getting the incidences right.
Will have ting about adapting the Watts up solution to an all flying tail configuration.
Martin
Old Dec 19, 2014, 11:24 AM
Essex BOF's Avatar
Joined Sep 2009
Picture of port wing panel with flaps & ailerons cut away from wing.
A tool I have used over many years now, old HSS hacksaw blade sharpened like a chisel at one end useful for notching the ribs to allow the T E for the flap hinge line and aileron hinge line. Then use a sanding notching block to sand to 1/8" deep.
Old Dec 19, 2014, 12:48 PM
So many projects...
United States, IN, West Lafayette
Joined Oct 2009
Subscribed!!!!
soarguy
soarguy is offline Find More Posts by soarguy
Discussion Phoenix models ASK 21-3.2 metre. Damian Couzoff Scale Sailplanes 2 Mar 02, 2014 10:43 AM
For Sale Electric 2 metre Fournier VMAR 1938Nebie Aircraft - Electric - Airplanes (FS/W) 3 Nov 20, 2013 09:56 AM
Wanted I'm looking for a forward fuselage from a 2.6 metre sized scale sailplane windysailor Aircraft - Sailplanes (FS/W) 5 Sep 20, 2013 02:08 PM
Discussion New releases by flyfly hobby-3 Metre fox , 2.6 Metre ask21 gliders Damian Couzoff Australia 12 Jul 26, 2010 06:11 AM
Discussion Winter project. Scratch build a 4 metre LS6. Tony D. Scale Sailplanes 0 Sep 21, 2006 09:36 PM
