Old Oct 05, 2013, 01:03 AM
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
sorry - could not get to the photos today - too busy playiing with the 3.5 meter Sage (center Pin) on the Vedder river
webbsolution is online now Find More Posts by webbsolution
Old Oct 05, 2013, 12:48 PM
Freund
ArfcDave's Avatar
United States, CA, Moorpark
Joined Apr 2012
After putting termite like trails squiggling all over a Sharon tip panel, I poured a lot boiling water on it with some results but finally streamed it into almost unnoticeable shape.
However the resin shrank a little showing the fabric weave of the surface layer of glass. I am quite happy with the tradeoff but avoiding silly damage is my now preferred method.
The first photos shows the area in question in extreme raking light and you can see the sparcap here. Photo 2 shows a more normal way to examine the surface.
It is almost not visible in normal lighting. Maybe seems a little duller but doesn't grab attention.
This was 10 square inches of damage. Probably best to leave small dents alone.
ArfcDave is offline Find More Posts by ArfcDave
Old Oct 08, 2013, 12:27 AM
belouder's Avatar
Seattle
Joined Aug 2005
D,
Once you fix these, I know this guy that makes these bitchin' boxes that are bullet proof......
BK
PS-You were missed.........
belouder is offline Find More Posts by belouder
Old Oct 08, 2013, 01:06 AM
Joined Jul 2007
You have to give me some highlights dude ! However, staying behind was good for the business model. I also managed to kill some salmon on the weekend so it was not a total loss.
I am gearing up for J in December now.
Question How to fix a dented leading edge in a bagged, foam cored wing. MAP123 Hand Launch 13 Aug 28, 2013 09:12 AM
Discussion How do you remove small dents in balsa before covering? eng30 Balsa Builders 13 Feb 04, 2013 05:01 PM
Discussion how well do small 4 strokes pull fuel from a lower tank? jeff262 Engines 13 Jan 28, 2013 07:39 PM
Discussion How do you get small dents out of Multiplex foam? eng30 Foamies (Kits) 2 Nov 30, 2011 08:00 AM
Discussion Hanger rash: How strong does the fin joint to the fuselage need to be? arukum17 The Builders Workshop 3 Feb 23, 2006 08:31 PM
