Old May 30, 2014, 10:27 PM
iron eagle's Avatar
United States, MA, Middleboro
Joined Jul 2007
Keeping the airframe lightweight has to be your primary build goal. Despite my tendency to overbuild I can still get them fairly light, my SD delta despite being fully sheathed came out at the same weight as a film covered stock one.
iron eagle is online now Find More Posts by iron eagle
Latest blog entry: The third time is a charm!
Old May 31, 2014, 12:07 AM
Artful Owl's Avatar
New Zealand, Canterbury, Christchurch
Joined Dec 2011
How dose one determine what the wing loading should be. Dose a plane have to produce as much lift at the weight of the plane?
Artful Owl is offline Find More Posts by Artful Owl
Old May 31, 2014, 03:48 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
Top sheeting repaired
vincent123 is offline Find More Posts by vincent123
Latest blog entry: FZ5: prototype time
Old May 31, 2014, 01:48 PM
iron eagle's Avatar
Joined Jul 2007
Vincent that came together very nice , you should be feeling a bit better.
Old May 31, 2014, 01:51 PM
iron eagle's Avatar
Joined Jul 2007
The lift produced has to be equal to the weight of the plane in order for it to fly. You determine what the wing loading should be on how you want the airplane to fly. Lighter = more responsive, Heavy = less responsive.
Edit to add:
My response is very simplistic this site has some very good insight into building and design considerations and there effect on performance.
http://www.airfieldmodels.com/inform...sign/index.htm
Old Jun 15, 2014, 04:01 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Found the time to remake the nose airinlet..
Re maiden should not be too long now
Old Jun 16, 2014, 09:21 AM
iron eagle's Avatar
Joined Jul 2007
Looking good.
That just leaves the fairing into the wing not bad.
Old Jun 29, 2014, 01:04 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Ready to fly another day!
Old Jun 29, 2014, 07:37 PM
iron eagle's Avatar
Joined Jul 2007
It looks as if nothing happened.
Watch your switches this time.
Old Jun 30, 2014, 01:47 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Checked the transmitter log, if I could find prove I flipped the swich. To be sure nothing else was going wrong there. And guess what? I found channel logging, indicating I flipped the switch alright... !
Help! Axial flux single phase motor design devmonkey Electric Motor Design and Construction 6 Mar 05, 2012 11:04 PM
Discussion Design and Test of 1 Phase BLM + Prop Helmut-Schweig Scratchbuilt Indoor and Micro Models 1 Feb 01, 2010 03:26 PM
Discussion How well would this canardish jet perform? (just design phase right now) GreenAce92 Foamies (Scratchbuilt) 5 Jan 16, 2009 08:14 AM
New A/P Plane - Initial Design Phase Buzz_Man Aerial Photography 4 Apr 21, 2005 01:33 AM
