Old Jan 19, 2013, 07:00 PM
Joined Mar 2012
Question
Minwax/coating, lead edges and hinge areas
Hello All,
Noob here. Will be getting my first "real" plane (after 3 years of cheap 2 channels - decent training i think/hope and much fun) and got the tip about using a few coats of Minwax Polycrylic to seal up the foam which sounds great. My questions...
Do you have to tape off control surface hinge areas to avoid the coating possibly gathering in there and binding it up? Or do the hinge areas still stay flexible after a few applications...
Do you still tape your leading edges and bottom (for belly landers) after using the coating? Or is it enough...
Welcome any suggestions and thanks very much. Your guys' helpfulness really makes the hobby.
cram is offline Find More Posts by cram
Old Jan 19, 2013, 07:02 PM
Joined Mar 2012
Oh, and any recommendations on spray versus paint on? I'd think for getting leading edges well, painting it on might be better. No clue, though.
Old Jan 19, 2013, 07:50 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
I always buy the brush on. It's much cheaper and it goes on very smooth. Using a brush you don't have to worry about the hinges as you just brush around them. I like to put a strip of tape over the leading edge and on the underside for belly landers. Filament tape on the bottom.
hoppy is offline Find More Posts by hoppy
Old Jan 19, 2013, 08:20 PM
Joined Mar 2012
Gotcha. I could just picture using spray and getting it in the creases along the control/hinge edges of the rudder, elevator, and ailerons and it building up...hindering movement. will use tape as well. thanks very much for the advice. can't wait to put lights on it, aiming them at the wing from the fuse, and seeing what the coating does.
Old Jan 20, 2013, 01:19 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
PS - I like the $Tree clear tape as it is very thin and light. The "brand name" shipping tapes can be quite heavy.
Question can i use CA hinges instead of robart hinges on a 65" edge 540? out of stock 3D Flying 3 Dec 07, 2014 07:37 PM
Discussion Modifying Flat Foam Leading Edges? bigblueswope 3D Foamies 4 Jan 25, 2013 10:19 PM
Question Pre-Coating Foam with Minwax Polycrylic FlipFlops365 Painting and Finishing Tips 4 Nov 14, 2010 11:40 PM
Discussion Leading Edge Leading Edge? gorgeflyer Slope 27 Sep 22, 2006 10:17 PM
Tape for leading edge and hinges? jeffs555 Scratchbuilt Indoor and Micro Models 10 Nov 11, 2002 08:11 PM
