Old Dec 07, 2012, 05:49 AM
Battery Powered==(*)==
tomcor's Avatar
Mesquite, Nevada
Joined Jan 2002
I killed my Beast by mistake :(
I decided to change my battery connections to micro deans. I messed up and ended up reversing the postive and negative. Plugged in battery and smoke came out. Unplugged real quick but looks like my mosfets got smoked. I should know better as i have done electronics for 40 years at least. Has anyone ever replaced the mosfets on the ar6400lbl?
Anyone have advice for repair of this receiver?
Never even got a chance to fly it.
Lesson learned always double check your connections before powering up.
tomcor is online now Find More Posts by tomcor
Old Dec 07, 2012, 09:53 AM
TurboRacer's Avatar
United States, CT, Waterbury
Joined Oct 2002
Gah, that sucks... You can replace them if you're good at soldering... You can get them on ebay for a couple bucks for a few I believe.
TurboRacer is offline Find More Posts by TurboRacer
Old Dec 07, 2012, 10:26 AM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Chimchim on RCG can probably fix them for $25.
I don't see the point of Micro Deans on these UMX planes. You lose balance and you are wasting time soldering a connector on a $4 battery.
I've bough UMX planes from people with micro deans and it's the first thing I get rid of.
Even the $4 batteries have the power to hover & punch out @ 5 minutes, so I'll stick with them for now.
UNGN is offline Find More Posts by UNGN
Old Dec 08, 2012, 05:32 AM
tomcor's Avatar
Mesquite, Nevada
Joined Jan 2002
Here is some pictures of the board showing the damage. Looks like it may be repairable.
Except I melted one servo with the soldering gun, Not a good week so far.
Does anyone know the value of the rear single capacitor?
Old Dec 08, 2012, 05:22 PM
United States, TN, Jackson
Joined Mar 2007
On mine the caps fried and not the FETs...I converted all of my planes over to JST connectors to make everything uniform...
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Dec 11, 2012, 06:42 PM
Joined Mar 2010
tomcor: Please check PMs. Good luck with your repairs!
jdre is offline Find More Posts by jdre
Old Dec 22, 2012, 12:24 PM
Your customer
Silverexpress's Avatar
Berkley, MI
Joined Dec 2009
Got some info on moosfets in my build logs. See my blog.
Silverexpress is offline Find More Posts by Silverexpress
Old Dec 22, 2012, 06:21 PM
Joined Mar 2010
OP (tomcor) has the board working now, after replacing the burned capacitors and resistors.
Old Dec 23, 2012, 07:16 AM
tomcor's Avatar
Mesquite, Nevada
Joined Jan 2002
Yes i got the board working by replacing the three 47uf smd caps and 2 smd resistors. Waiting on my replacement servo.
Old Jan 03, 2013, 04:05 AM
tomcor's Avatar
Mesquite, Nevada
Joined Jan 2002
I got the Beast back together and did a maiden flight today Nice!! Like how it flys.
Took the 10mph wind good.
Old Jan 03, 2013, 09:30 PM
Joined Mar 2010
Beast in wind
Good to hear it's back in the air I can fly mine in winds stronger than I can land it properly, set down and lifts off or rolls in reverse..
Discussion My mistake Guga Aerial Photography 0 Aug 23, 2012 08:43 AM
Discussion Newbie stupid fpv mistake !!! Lost my quad rotor jxvot FPV Talk 1 Jun 03, 2012 01:52 PM
Discussion Top mistakes that can kill your batteries! Please list gassper Batteries and Chargers 29 Sep 12, 2006 10:50 PM
