Old Dec 09, 2003, 11:31 PM
Marshfield, Wisconsin, United States
Joined Sep 2002
Razor 400 and 10t Pinion is Good!
Swallowed my whatever and wired it up tonight. The 400 on 2s lipos draws 5amp with direct drive tail, 15minutes of air time and hovers at half throttle. Mucho power compared to speed 300 setup.
HOwever, do not try to program a pheonix esc with ADD or after a beer. Man I thought the bloody phone would never stop ringing, or the interuptions while I tried to program the brake out and work through the blinking lights and tone. shades of Simon!
It really is not an intuitive process.
On the other hand, the battery pack after 15 minutes was at 120 and the motor 105. lBarely pushing it. Had to stay on the throttle more to stay out of theceiling.
Thanks for all the advice.
Stuka
stuka is offline Find More Posts by stuka
Old Dec 10, 2003, 12:00 AM
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
What helicopter are you flying?
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
Old Dec 10, 2003, 12:06 AM
fatboywings's Avatar
Newcastle Australia
Joined Nov 2002
what is 120 and 105
Is this temp in Farenhiet or something?
Sorry, i am a metric student.
fatboywings is offline Find More Posts by fatboywings
Old Dec 10, 2003, 01:11 AM
I see the future.
Yukonho's Avatar
Halfmoon Bay, BC, Canada
Joined Feb 2002
45 and 38 in celcius (approx)
Yukonho is offline Find More Posts by Yukonho
Old Dec 10, 2003, 10:58 AM
Alphabandaid
Joined May 2003
Sorry
IN my enthusiasim and can of celebratory beer I failed to mention I fly(hover only tail in) a Hummingbird. The numbers are temperatures in farenheit. Guess the universal thing woudl have been to say the battery is cooler asd the motor as well than the speed 300 setup and 10t pinionn
My apologies to those using the metirc system. Some units I just can't conceptualize metrically like temps.
Stuka
aplphabandaid is offline Find More Posts by aplphabandaid
Old Dec 10, 2003, 11:41 AM
Mesmer's Avatar
Napa, CA
Joined Apr 2003
Stuka-
I've got a RZ400 with a GWS "C" pinion on it (I don't know how many teeth are on a C pinion). Do the GWS EPS 300 pinion gears mesh well with the HB main gear? If so I might be try your combo. Would the RZ400 be too much for the stock geared tail motor, or do you have to run the direct drive tail motor?
Mesmer is offline Find More Posts by Mesmer
Old Dec 10, 2003, 03:51 PM
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Sweet.. That's good news.. I guess a 350 in this thing would go ZOOOOM.. Sure wish I could find a V2 Heli motor though..
Tram is offline Find More Posts by Tram
Old Dec 10, 2003, 04:29 PM
Joined Aug 2000
Tram, I'd bet that the Himax 2015 4200 would work well in the place of a RazorV2. Sure the Himax is hard to find right now, but it should be readily available in about 10 days.
-Jim
Old Dec 10, 2003, 05:25 PM
Alphabandaid
Joined May 2003
Once Again Science Triumphs over Ignorance and Superstition!
THe GWS c gear pinion is 12 tooth which would work, but ups the amp load to edge and beyond for 1200 etech, i.e. 8 amps +
The ten tooth comes with a motor in the D gearbox, ile 10 tooth.
The pinions mesh well, or seem to in my lmiited experience. I had to ca my pinion on, but it flew over thirty minutes woihtou loosing it jsut after gluing it to th eshaft with the help of ca accelerator.
At five amps max this is a perfect power/load comobiantion im my mind, what little is left after 56 years.
Almost forgot, my lipo's are 2s.
Old Dec 10, 2003, 05:30 PM
Mesmer's Avatar
Napa, CA
Joined Apr 2003
That's great info thanks
Old Dec 10, 2003, 06:06 PM
Tram's Avatar
Florence, Al
Joined Oct 2000
Jim-
Sweet- it won't be until after christmas that I will be needing the motor.. I am on a "restricted" budget until after christmas, that is when I will buy my heli.
aplphabandaid-
So, are you saying a D pinion would work better? To use a brushless setup will i need a new pinion or spur gear?
I am clueless to all this microheli..
Razor 400 and GWS pinion Ted Bronson Power Systems 4 Jan 13, 2004 08:00 PM
Razor 400 versus 10t 010 test & thrust results Tres Wright Power Systems 49 Aug 05, 2003 01:22 AM
Pinion from EPS 300 to Razor 400? bugleboy Power Systems 2 May 31, 2003 02:47 PM
Razor 400 and pinion gear Placement stuka Power Systems 12 May 26, 2003 01:46 PM
Razor 400 or AF010 10T for GWS? kscbob1 Power Systems 4 Mar 31, 2003 10:53 PM
