Old Today, 07:03 AM
Joined Sep 2014
Tacon 110 12S test results
2X 3300mah Turnigy nano 35c
120a HV ESC
12S BEC
18x8 XOAR
Max Throttle: 51%
Peak Watts: 2050w
Peak V: 45.2
Peak AMP: 45
Avg Watts after 1min: 1950
Starting Voltage: 50.5
17x10 APC
Max Throttle: 63%
Peak Watts: 2061
Peak V: 45.04
Peak AMP: 45.3
Avg Watts after 1min: 1960
Starting Voltage: 49.0
Motor was barely warm after these tests.
I pushed it to 2350W for about 20 secs with the last setup. It survived. It's just as beefy as the 160. Wonder if these are under rated?
guldukat is offline Find More Posts by guldukat
Old Today, 07:37 AM
United States, IL, Glenwood
Joined Nov 2013
Unless I am missing somthing here. If you have to limit the throttle too run a prop on a particular motor. To keep it from burning up wouldn't that mean that it's a poor motor choice for the application. If I'm wrong please explane. It just does not make any sence too me. I'm sure there is something I'm missing.
Gregertman is online now Find More Posts by Gregertman
Old Today, 09:01 AM
United States, NC, Asheville
Joined Sep 2012
talcon 110 8s prop xore 19 8 pja and pjn. i think the gas prop has more stall thrust.
mattnat is online now Find More Posts by mattnat
Old Today, 09:21 AM
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Absolutely nothing wrong about that and the only sense to it is that it's a case of making due with what you have. With Hacker and Motrolfly in this power class, we're running motors between 2 and 5 ounces lighter, to more power, and not having to restrict anything. We're also paying $160 more, but I'd never do what I'm doing with Hacker and Motrolfly motors to any other motor in this power class, less or more expensive.
Aeroplayin is online now Find More Posts by Aeroplayin
Old Today, 10:20 AM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Price-point is a subjective decision, but when I have $1,700 tied up in an airplane, I'm more interested in protecting $1,540 than I am about saving $160. Plus, I'm running a 21x10 prop, so the cheaper motor won't give me the performance I'm looking for either, without putting the investment at an even bigger risk.
Old Today, 10:46 AM
Joined Nov 2013
Ok good to know that in a pinch that is a reasonable solution to using what you have. I'm with you if you already have 1500 to 1700 ish wraped up in a plane. I myself wouldn't skimp on the motor and risk it and also loose performance. If you already have the best plane why not use the best motor. That's the way I see it. But I also see if your on a budget what else are you going to do.
Old Today, 03:04 PM
Joined Sep 2014
I always like trying cheaper alternatives. hackers have a bad reputation - they denied warranty replacements. i maidened the ef edge 74 with the 20x8 with the tacon. hovers at mid throttle but still need to get used to this aircraft. the hv mi turnigy servo's are a great setup for this. super fast at 0.06 secs. still too early to deem the tacon's reliable. only 4 flights. the entire setup is usd 9xx.xx.
Old Today, 07:20 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
I've had eleven Hackers and nine Motrolflys and never had a problem with any 28 pole Hackers -- A60 to the Q80. I actually think they have one of the best reputations out there along with Motrolfly. I have had problems with every other motor brand I've owned, and I won't bother to list them, but I've settled on Hacker and Motrolfly for now. I would add that Torque motors in the sizes we;ve discussed also have a good reputation.
We've been discussing motors, ESC, batteries, props, and a few other electric components here since 2011 and I think we're at the point where we know good components from bad. I have no problem saying unequivocally from experience that the Hacker and Motrolfly are head and shoulders above most of the other brands from 2800 Watts and up (have not tried Plettenberg yet), and there is certainly no comparison with anything you'll find on Hobbypartz or Hobbyking in the $25 to $100 range. I wish they would, but they don't give away good motors.
Question RC kits for experimenting with flight control systems SubZer0 DIY Electronics 11 Oct 12, 2011 09:58 AM
Wanted left wing for extreme flight yellow and black 74 yak hondaboy92hatch Aircraft - Fuel - Airplanes (FS/W) 0 Sep 29, 2011 11:18 AM
Discussion Extreme power systems & Royal Evo 12 rbehrends Radios 5 Oct 11, 2007 06:55 PM
Discussion Battery for Logo 10 - Thunder Power "eXtreme" 5S 4600 or Flight Power 5S 3700? WeatherB Electric Heli Talk 6 Jan 25, 2007 11:29 PM
