Old Feb 07, 2011, 08:03 AM
Tri-City Airport Municipal, Tennesse, United States
Joined Oct 2003
Help!
Confused how to hook up BEC on T-copter
Finishing my T-copter using the 401b gyros. I have the BEC but am confused where to hook it up on the receiver. I have a 6 channel receiver and all the spots are taken with the motor/gyros on 1,2,6. The yellow wire from the gyros on 3. the tail servo/gyro on 4,5. Can i use a Y connector to #3 or #5?
Thanks in advance for the help.
Jake.
bigjake is online now Find More Posts by bigjake
Old Feb 07, 2011, 08:06 AM
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
Y CONNECTOR on any channel you like bruv
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old Feb 07, 2011, 08:17 AM
Joined Jan 2006
Jake.
since you're using ch 3 for the signal wire of your gyros (ch1,2,6) you can connect the red and black wire to channel 3 using the same plug so no need to use a Y connector since your plug on ch 3 has only the yellow wire.
i hope i'm clear.
reminder since you'll be using a BEC you have to disconnect the red wire of your ESC.
HTH!
mandis is offline Find More Posts by mandis
Old Feb 07, 2011, 08:29 AM
Joined Oct 2003
I have to remove all three red wires from all the escs? What would happen if i left them in place? Is there another way to hook up without removing the esc red wires?
Thanks for the quick replies!
Jake
Old Feb 07, 2011, 10:30 AM
Joined Feb 2007
i hope i'm clear.
HTH!
good call i stand corrected
Help! HELP ! How do I hook up this prop ? omarko Power Systems 5 Jan 30, 2011 08:20 PM
Discussion sbec + esc - How do I hook it up ? please help ! omarko Power Systems 12 Jan 10, 2011 07:19 PM
Discussion How to hook up night lights FLAME747 Night Flying 13 Nov 28, 2010 08:50 AM
Discussion how do you hook an ESC with built in BEC up to the reviever? (youtube video included) at3buell Scale Kit/Scratch Built 10 May 08, 2008 10:43 PM
Discussion how to hook up this bec BOBBY1017 Power Systems 2 Jun 10, 2007 04:08 AM
