Old Jun 10, 2014, 03:03 PM
United States, AR, Lockesburg
Joined Feb 2012
I was not clear, as most of the time. I will try again. With the plane trimmed for hands off level flight you should be able to go inverted and still have hands off level flight. I do not under stand but the length of the plane plays a role in this. James, please correct me if I am wrong.
Again, If you are happy with the way it flys - it is flying as beautiful as the covering job you put on it. Just fly it a enjoy a really good looking airplane!
Petrie is offline Find More Posts by Petrie
Old Jun 10, 2014, 07:33 PM
Cherokee Flyer's Avatar
United States, KS, Rose Hill
Joined Sep 2007
What you are checking with the amount of down to hold inverted flight is the C/G. If it is back, it will climb, if it is front, it will descend.
L.
Cherokee Flyer is offline Find More Posts by Cherokee Flyer
Old Jun 10, 2014, 09:40 PM
Joined Feb 2012
You are right Cherokee Flyer. I stand corrected. When I think back I was moving the wing forward to get the CG back further. I was just remembering it flying better after I moved the wing forward. Sorry
Old Jun 10, 2014, 11:27 PM
Joined Sep 2007
No reason to apologise, I just learned that late in life! Easiest way to check the C/G after you have it close.
L.
Old Jun 10, 2014, 11:33 PM
Joined Jul 2007
Hi, I saw this thread and had to have one! It's in the mail. I have built a few arf's but this will be my first kit build. I have a extra e flight park 450, park 400 and a 25amp electrafly esc laying around...which motor would be better? Will the park 400 be better? I'm assuming a 10x4.7 prop will work with either motor. I don't have a watt meter to test different prop combo's or know how to use a wattmeter. I would like good vertical pullout. I'm not new to flying but this electric stuff is over my head. I have a few 1500 to 2200mah 3 cell lipo's to power it. I also have a hurc 18 amp esc but assume the 25 will be better.
crrdr97 is offline Find More Posts by crrdr97
Old Jun 17, 2014, 01:13 AM
Flying Inverted
StearmanSam's Avatar
Joined May 2006
Nice looking plane!
StearmanSam is offline Find More Posts by StearmanSam
Old Sep 02, 2014, 12:43 PM
Joined Sep 2007
James,
I finally put the long fuselage on the S/S and got the heat gun out like you told me to. Wow does that smooth out the airplane, I didn't think it would make that much difference. It is an entirely different airplane, nice and smooth.
L.
Old Sep 02, 2014, 03:54 PM
Joined Feb 2012
Can you explain this Cherokee? I am thinking you take a heat gun to the CF fuse and bend it until square, is that right?
Originally Posted by Cherokee Flyer View Post
James,
L.
Old Sep 02, 2014, 04:43 PM
Joined Sep 2007
Yep, some of the 10mm square tubes that James got were twisted, so you use a heat gun and GENTLE heat to square up the wing and tail. The tube is an extended one that he has for the SlowSticks. Makes a big difference how it flys. He gives an explanation a couple pages back. See report 2510.
L.
Old Jan 30, 2015, 05:06 PM
Deadstick 8409's Avatar
Joined May 2010
How much heavier is the balsa wing vs. the original?
Building a FPV/ MIA ultralight conversion. Is the wing kit a plug and play direct swap out, or do you need the whole kit and basically start over?
Deadstick 8409 is offline Find More Posts by Deadstick 8409
Old Jan 30, 2015, 05:43 PM
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
It's been a long time since I had a regular slow stick to put on a scale. I am sure that information is somewhere on this thread. The short kit is all you need to upgrade a slow stick. I recommend tail and wing not just the wing. The SSX makes a great FPV platform.
James
jkarpy is offline Find More Posts by jkarpy
Build Log Quick build Slow Stick mattyfly4fun Foamies (Scratchbuilt) 14 Feb 17, 2013 11:12 PM
Discussion Will this Slow Stick build "work"? chapped Beginner Training Area (Aircraft-Electric) 36 Mar 08, 2010 06:29 PM
Discussion Help me with a brushless Slow Stick build chapped Beginner Training Area (Aircraft-Electric) 10 Jan 13, 2010 11:27 AM
Sold Millenium X-gear Carbon Fiber Landing gear for Slow Stick Scirocco14 Aircraft - General - Miscellaneous (FS/W) 2 Jan 11, 2010 10:38 PM
