Old Aug 20, 2005, 09:33 AM
FUBAR
Joined Jan 2005
Idea
Nitro Engine -> Dynamo -> Electric Motor
Anyone ever devised a working electric model that is powered by an alternator/dynamo hooked upto a nitro engine???
Phantasm141 is offline Find More Posts by Phantasm141
Old Aug 24, 2005, 04:35 PM
York Electronics
Gary Warner's Avatar
Dallas Tx USA
Joined Apr 1999
Why?
Gary Warner is offline Find More Posts by Gary Warner
Old Aug 24, 2005, 05:06 PM
Dimension Engineering
Akron, Ohio
Joined Jan 2002
Gary,haven't you heard how much better fuel economy these new hybrids get?
Comatose is offline Find More Posts by Comatose
Old Aug 24, 2005, 05:30 PM
FUBAR
Joined Jan 2005
Originally Posted by Gary Warner
Why?
Why what? Was just a thought, considering a few points, doesn't the A-10 thunderbolt have electric engines???(the real one that is), and trains use this sort of system...
Old Aug 24, 2005, 05:44 PM
Dan Baldwin's Avatar
United States, CA, Norwalk
Joined Apr 2004
The A/OA-10 is a single place, pressurized, low wing and tail aircraft with two General Electric TF-34-100/A turbo-fan engines
snicker
LOL
Sorry. Couldn't help myself
Dan
Dan Baldwin is offline Find More Posts by Dan Baldwin
Old Aug 24, 2005, 05:53 PM
FUBAR
Joined Jan 2005
lol, well i guess someone has already made an R/C model that works like this, as for the economy...
Old Aug 25, 2005, 06:45 AM
flying thing
lostrider's Avatar
Joined Mar 2005
converting an energy to other energy;
result is always losing some energy.
nitro motor weight+fuel weight > an a good battery
(nitro motor weight+fuel weight)/performance < (an a good battery)/performance
my 0.02 turkish lira
lostrider is offline Find More Posts by lostrider
Old Aug 29, 2005, 11:08 AM
York Electronics
Dallas Tx USA
Joined Apr 1999
Trains use e-motors because they need tons of torque - it's a 'torque converter' of sorts. E-motors develop maximum torque when stalled. I guess a plane that needed to turn a HUGE prop at very slow speeds could benefit from this kind of energy conversion.
If electric motor driven props were mandated, then the losses of energy could well be worth it, given the energy density of liquid fuel. Again though, it would be a waste if engine driven props were an option.
Also, I could see a military requirement where a drone was to travel a long distance to a target with the engine running then shut the engine down and fly on batteries quietly over a target. This could extend the range of a naturally quite e-powered drone.
Gary
Old Aug 29, 2005, 02:33 PM
FUBAR
Joined Jan 2005
Ok so the only advantage is torque, so it would be fairly ideal for a helicopter to have this system?
Old Aug 29, 2005, 03:15 PM
York Electronics
Dallas Tx USA
Joined Apr 1999
No.
Gearing of an engine multiplies the engine's torque more efficently than a dynamo will.
Gary
Old Aug 30, 2005, 07:27 PM
United States, SC, Irmo
Joined Jul 2004
And don't forget the extra weight you're adding to the airframe.
50+AirYears is offline Find More Posts by 50+AirYears
Old Aug 31, 2005, 02:48 PM
Alamo Park, Yerba Buena
Joined Jun 2004
What if you needed to turn the prop on or off, you need a starter mounted to the engine. This heavy starter, is it not essentially the guts of a dynamo?
Ram.
sesat is offline Find More Posts by sesat
Old Sep 12, 2005, 01:19 AM
UK
Joined Sep 2005
Motors and dynamos can both be > 95% efficient, and more than 90% efficient together. Gears are generally around 90% efficient, so I agree there is not much difference, for any single gear ratio one could name.
However the dynamo/motor combination provides fantastic torque at stopped and extremely slow speeds (the equivalent of an extremely high gear ratio) without losing top end speed. This is roughly equivalent to an infinitely variable automatic gearbox.
MatC is offline Find More Posts by MatC
Old Sep 21, 2005, 05:07 PM
Switzerland
Joined Sep 2005
what about EDFs instead of a prop in the nose?
diego
dj2u is offline Find More Posts by dj2u
Old Sep 22, 2005, 08:58 AM
San Carlos, California, United States
Joined May 2002
The alternator + motor will weigh much more than a gear reduction system.
Toshi
TMorita is offline Find More Posts by TMorita
Electric Motor equivalent to the G23/G26 gas engine for blimp use? Frisk151 Power Systems 5 Jun 29, 2009 07:18 AM
.074 engine vs. electric motor--which has more "noise" rsay Radios 7 Mar 06, 2005 02:14 AM
Conversion project - what speed electric motor is equal to .049 glow engine try2fly Electric Sailplanes 0 Jan 06, 2002 01:24 AM
