Old Oct 24, 2014, 09:10 AM
Fly more Foam
sam51401's Avatar
United States, IN, Sellersburg
Joined Jun 2004
Build Log
Composite T-33A from EasyTiger Models
Before anyone has any comments on starting this thread, as my wife tells me "Survive the crash and move on".
I'm starting a new thread from the other in that i do not have full edit and control rights for the previous thread. The original was started over two years back and the plane did not become availible till this past September from EasyTiger Models.
Starting a new thread has its merits behind the scene so to speak for the continued support from EasyTiger.
Saying this, i did get a reply back on the CG and will post that with more pics in the coming week along with a suitable retract selection as has been noted previously.
Just so everyone may know where I stand, this plane was ordered direct from EasyTiger and as of current, he is the only one offering this plane. I DO NOT represent ETM in any form and I purchased this plane at list price and shipping that is shown on the web site.
There fore, this is a totally UNBIASED review and personal changes made at my choosing.
Being that this and the RCL foam is the only T33 at this size currently being offered, I would hope that others will find this helpful and insightful.
Stay tuned as I continue.
Sam
Links that were already referenced and posted in the previous threads can be found here.
http://www.rcjetaddiction.com/forum/...-new-90mm-t-33), made back in 2013
http://www.rcgroups.com/forums/showt...5#post29562109 , Posted pics of the wing in previous thread
sam51401 is offline Find More Posts by sam51401
Old Oct 24, 2014, 09:52 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
So what gear have you decided on?
AIR SALLY is offline Find More Posts by AIR SALLY
Old Oct 24, 2014, 10:41 AM
Fly more Foam
sam51401's Avatar
Joined Jun 2004
Looking through the selection at MotionRC. They are Freewing and i believe a 4mm pin will work. They have a 5mm pin version also so just have to checking mounting dimensions.
Considering using just 5/32" wire struts with the gear covers for now. What you think?
Hows your recovery going?
Old Oct 24, 2014, 04:27 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
In a sling,frustrating. Spent 2.5 hr's to swap a retract in a FM's t-28.
I would aim for the 5mm set.I hate extracts.the limit switches are crap.eflite uses a better switch.give me air any day.I have tams minis in a9lbs f-16 they are the best.
Old Oct 24, 2014, 04:48 PM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
R
I'm with you Rodger. Check out these Spring Airs.
http://www.retracts.com/
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Oct 24, 2014, 05:17 PM
Fly more Foam
sam51401's Avatar
Joined Jun 2004
After chatting with CS person at MotionRC, i decided to TRY the nose retract unit that is used on the Stinger 90. Im trying to go with the least amount of modifying and a less expensive alternative to the EFlites that were referenced in 2013'.
I opted for this unit and it fits a 5/32 wire strut and still steerable. Be here sometimes next week when my LHS gets the MotionRC order.
Rodger, i understand being "one handed" so to speak. I am still planning a T38 build once the T-bird is flying. Its calling my name!!
Old Oct 25, 2014, 08:43 AM
EDF Jet Jam 2015 , May 28-31
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Looking forward to your review.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Oct 25, 2014, 07:04 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Sam as soon as I get a few more days behind me I'm going to work on the 38
Old Nov 07, 2014, 05:41 PM
Fly more Foam
sam51401's Avatar
Joined Jun 2004
Hey people!! Im shooting ot get some shop time this Sunday to get things roll'n but im going to watch "Interstellar" as a birthday present to me.
Got the Stinger 90 nose unit from MotionRC and it fits like a glove! Metal trunion for 5/32" wire pins or a wire strut. I still plan on wire strut with Robart strut covers so going to get that mounted. If anyone were to ask as to retracts, i would pitch the Stinger 90 retract set from MotionRC and then use either wire or shock struts.
PS Carl S. has one of these for sale in the classifieds, he will even split shipping!
Old Nov 07, 2014, 08:31 PM
TBolt's Avatar
United States, AZ, Queen Creek
Joined May 2004
PS Carl S. has one of these for sale in the classifieds, he will even split shipping![/QUOTE]
Not anymore!
Thank you Carl.
I'll be following your thread for when I get the chance to build this beauty.
Victor
TBolt is offline Find More Posts by TBolt
Old Nov 13, 2014, 10:31 PM
TBolt's Avatar
Joined May 2004
Sam,
So, are you recommending the nose and main gear from the Stinger 90?
Victor
Old Nov 14, 2014, 08:53 AM
Fly more Foam
sam51401's Avatar
Joined Jun 2004
At this point i can and will recommend the nose unit for sure as this is the only one i have ordered. As to the mains, I havent recieved a set to confirm and i went ahead and purchased the EFlite retracts based on the post from Curtis back in early 13'. After recieveing the plane is when i realized that at lest the EF nose unit would not work for the intended stock mounting.
I have the Tams' upgraded trunions for the EFlites mains and only after getting the Stinger nose unit that i made the assumption that the Stinger mains would probably work being nearly identical to the EFlites. The Stinger set comes with 4.1mm or you may find the same retract fitted with a 5.1mm trunion so i leave the solid recommendation on the mains open on the Stinger 90 set. EFlites fit fine but the 15-25 set will need the upgraded metal trunion to use 5/32" wire struts or pins for this plane.
Sam
Old Nov 14, 2014, 12:35 PM
TBolt's Avatar
Joined May 2004
thanks for the info, the kit I purchased from Carl should arrive today (hopefully I get home before the wife)
Victor
Old Jan 22, 2015, 11:22 PM
TBolt's Avatar
Joined May 2004
Any updates on your build?
Old Jan 25, 2015, 09:47 AM
Fly more Foam
sam51401's Avatar
Joined Jun 2004
I did receive the retracts before Dec but ALL building has come to a holt since my shop is my unheated garage. The hose on my propane heater melted off at the heater connection and im looking to continue shortly. As time is passing by and the building season I have is getting shorter toward spring, I really need to get my butt moving on my projects.
I did manage to cut the nose gear door free.
For Sale Vintage Kyosho T-33A Shooting Star EDF, NEW IN BOX mylestone Aircraft - Electric - Jets (FS/W) 1 Nov 02, 2014 02:11 PM
Help! t-33a shooting star fire18e52 Power Systems 1 Sep 25, 2014 11:58 AM
Discussion C-17 Globemaster from Easytiger Models with Video DickWeddingen Foamy EDFs 39 Nov 03, 2010 05:11 PM
Discussion Easytiger Models T-50 Golden Eagle new thread doctorjimmy Foamy EDFs 4 Sep 10, 2010 10:56 PM
Discussion Super icon a-5, fully amphibious seaplane from easytiger models Fast Freddy Waterplanes 0 Aug 24, 2010 04:04 PM
