Old Jun 29, 2014, 07:53 AM
Joined Jun 2014
Question
LiPo cell damage on side
Just made my first maiden flight. I was counting on crashing, but I didn't expect the battery to come loose and take an unfortunate hit.
That hole in one cell looks pretty bad to me, but I'm a total novice. I haven't charged nor used the battery since the hit, but I checked the voltages and all cells are still balanced. No smoke, puffs or anything except that hole. At the moment the whole pack is outdoors on stone tiles just in case.
My plan is to remove the single damaged cell and dispose of it (salt water and what-not), while keeping the two other cells. Does this sound reasonable? Is it paranoid? Are the two remaining cells scrap as well?
Sorry if this is a repeated question, just want to make sure I'm doing the right thing after seeing all those LoPo fire videos...
miniyou is offline Find More Posts by miniyou
Old Jun 29, 2014, 09:31 AM
United States, FL, Orlando
Joined Oct 2013
A puncture of the cell is grounds for an immediate discharge and disposal. The internal chemistry will quickly be contaminated and destroyed by contact with air (at best) and could cause a fire (at worst).
I wouldn't bother trying to save the other cells unless you have a specific use for a 1-less-cell battery. Unsoldering cells can be hard (lead-free solder + battery is sensitive to high temp) and risks shorting them out while new batteries are cheap. If you really want to go that route, I would completely discharge just the damaged cell through the appropriate balance tap connector. Then you can plan out removing it.
Maybe just play it safe, discharge all the cells completely then practice unsoldering and resoldering the cells once the entire battery is dead and inert.
CerealKiller159 is offline Find More Posts by CerealKiller159
Old Jun 29, 2014, 10:32 AM
Joined Jun 2014
Sounds reasonable, thanks
Old Jun 29, 2014, 11:25 AM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Pretty solid advice.
hoppy is offline Find More Posts by hoppy
Wanted 70-90mm Foam EDF airframe (with side intake), used or damaged edwen303 Aircraft - Electric - Jets (FS/W) 2 May 21, 2014 02:36 AM
Wanted WTB Trex 800 DFC main side frame, Used/Damaged SurfSloper Aircraft - Electric - Helis (FS/W) 1 Apr 08, 2014 01:17 PM
Help! Charger only shows 2 cells on 3 cell lipo loosho Batteries and Chargers 7 Feb 15, 2014 08:00 AM
Discussion 55mm edf unit on 5 cell lipo xrx1113 Electric Ducted Fan Jet Talk 3 Nov 20, 2013 01:06 PM
Sold PULSE LIPO 2250mAh 11.1V 45C- ULTRA POWER SERIES 3s damaged lipo vyper2k1 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 01, 2013 09:57 PM
