Old Jan 14, 2013, 11:45 AM
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
Help!
waterproofing electronics
Hi - I'm converting my Funcub to a water plane by adding floats. I've heard about applying Corrosion X to the elctronics but am not sure how to use it. Do I coat all the electronic (receiver, esc, motor, battery, servos) components internally? Do I open up the components to gain access to the circuitry? How much Corrosion X does one apply? Thanks for any advice.
David
dno264 is offline Find More Posts by dno264
Latest blog entry: Alfa Airacobra
Old Jan 14, 2013, 03:42 PM
Flutter-Bys are fun
Conehead's Avatar
United States, MI, Honor
Joined Dec 2005
I think most of the pilots who use Corrosion-X RED Label, just take the componets out, spray the Corrosion-X on and in the componets. Let them drain out, usually overnight. Many take the bottoms off the servos and spray those parts. Let the Corrosion-X drain out and then reassemble the servos.
I have used Corrosion-X on my rec and esc. I didn't do the servos, didn't have any trouble with the servos, but the next assembly of my Seawind, I will do the servos.
I didn't cut the shrink wrap off the esc or the rec. I just sprayed it in both ends and let it drain. Same with the rec.
Conehead
Orrin Eldred
Conehead is online now Find More Posts by Conehead
Old Jan 14, 2013, 08:48 PM
Zoomer-Ron's Avatar
United States, FL, The Villages
Joined Jul 2002
Buy the pump spray bottle. Pour it into a suitable size container, like a foam drinking cup. Dunk the entire RX or ESC, and let it drain out for a day. I have not tried this with servos yet.
Zoomer-Ron is offline Find More Posts by Zoomer-Ron
Old Jan 14, 2013, 10:02 PM
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
+1 on the use of CorrosionX.\
You probably shouldn't dunk the servos though. Only the tiny PC board needs treating. You can spray the board or use a small brush and paint the board with CorrosionX. You need to treat the servo wire exit point or seal it with Vaseline or hot melt. You should also consider putting Vaseline on the servo output shaft and under the servo arm to seal the servo case opening where the shaft exits.
McD
kingsflyer is offline Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Jan 14, 2013, 11:51 PM
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
Thanks for all the advice. Much appreciated.
David
Old Jan 21, 2013, 07:33 PM
teryn1's Avatar
Tucson, AZ
Joined Aug 2004
Corrosionx is awesome - I put it on almost everything
teryn1 is offline Find More Posts by teryn1
Old Jan 23, 2013, 05:02 AM
Per Ardua Ad Astra
Berkie's Avatar
Australia, VIC, Rosebud
Joined Feb 2007
Also, I Cx ALL connectors
Can;t see how you could get away with not doing so, because water will get in to them, then poof! Blue smoke comes out and that stuff is really hard to get back in!
Kev
Berkie is online now Find More Posts by Berkie
Old Jan 24, 2013, 03:19 PM
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
McD
I agree. The thing to do with servos is keep the water out. The only problem I have had with a servo was a result of water in the feedback pot, not the circuit board, and I don't think you should treat the pot with CorrosionX.
By the way, once I dried everything thoroughly and disassembled and cleaned the pot, the servo worked fine again.
The most vulnerable component, and the one most in need of CorrosionX, is the ESC, as it will fail if the throttle is opened while wet.
Daedalus66 is offline Find More Posts by Daedalus66
Old Jan 24, 2013, 05:59 PM
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
All good advice. Thanks.
For Sale iBdry Waterproof Cell Phone/Electronics Case Goanna Non R/C Items (FS/W) 0 Jun 09, 2012 03:54 PM
Discussion Using this new process can we waterproof out quad electronics? goldsworthy Multirotor Talk 5 Apr 11, 2012 10:16 AM
How do you waterproof electronics for float plane?? duganderson Waterplanes 20 Dec 15, 2006 11:23 PM
Waterproofing electronics WillisTx Waterplanes 13 Jan 28, 2005 12:23 PM
