Old Nov 25, 2012, 04:14 PM
The lunatic is on the grass
ridgewalker's Avatar
Joined Aug 2008
Foxtech 5.8ghz 200mW RP-SMA confusion,help please.
Ordered the 5.8ghz Foxtech 200mW vtx/rx and forgot about the RP-SMA adapters.
Would like to order the adapters from Readymade but am confused as to which is the correct one to pick up for the Foxtech vtx/vrx.
These are the two from Readymade...
(1) http://www.readymaderc.com/store/ind...roducts_id=432
(2) http://www.readymaderc.com/store/ind...roducts_id=614
ridgewalker is offline Find More Posts by ridgewalker
Old Nov 25, 2012, 04:46 PM
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
read this
http://www.sparkfun.com/tutorials/140
BCSaltchucker is online now Find More Posts by BCSaltchucker
Old Nov 25, 2012, 05:18 PM
Joined Aug 2008
Thanks for the link,read it but don't have the vtx/vrx in hand er else i could just look at the pics and figure it out.
My antennas are SMA-male, so if the foxtech vtx/vrx has a pin on the inside of the socket/threads on outside then i'm thinking this would be the correct one http://www.readymaderc.com/store/ind...roducts_id=432
My SMA antenna with a pin in the center will screw on to the end with the threads on the outside and if the foxtech vtx/vrx has a pin sticking out of the socket and threads on the outside then the other end of the adapter should screw on to the vtx/vrx.
Sound like i'm on the right track????
Old Nov 26, 2012, 10:43 AM
Joined Aug 2008
Guess i'll just have to wait til the gear comes in to know for sure.
Unless someone can post/link up a picture of what the inside of the antenna socket on the Foxtech vtx/vrx..
Old Nov 26, 2012, 12:17 PM
Joined Aug 2008
Some info from another thread,figured it may be helpful for others who may come across this thread in a search.
Originally Posted by Daemon View Post
Sparkfun's tutorial is wrong on a couple key points.
It's more consistent than they make it out to be.
The center pin is not what determines the "male"-ness of the SMA connectors.
If you look closely at the pictures of *all* male and female SMA connectors
regardless of polarity, you'll see that the barrel the surrounds
the center insulator on a male connector fits *into* the depression
in the female connector. That's the male bit that fits in the female bit.
Standard SMA connectors happen to have a pin on the male side, and a
hole for the pin on the female side, but that is incidental.
As for why RP-SMA came about. Sparkfun says it's for FCC Part 15
compliance, but doesn't explain why. The reason is that FCC Part 15
compliance requires that both the Rf module and its antenna be certified
as a single unit. If you take a Part 15 compliant device and replace
the antenna with a different one, then it is no longer compliant. Period.
The intent behind creating RP-SMA was to make a new non-standard
antenna connector that was hard to find replacements for (as they
were all regular SMA before that). So they just swapped the
locations of the center pin and hole between the male and female connectors.
Of course what really happened was that a zillion different RP-SMA antennas
popped up, and it became the new standard for all Part 15 devices (wifi routers, chief among them).
ian
http://www.rcgroups.com/forums/showt...3#post22319327
Haven't been able to find a pic of the inside of the Foxtech vtx/vrx antenna plug/socket in my searches but pretty sure this is the adapter i need.
Old Nov 26, 2012, 06:03 PM
Joined Apr 2010
I got the female to femal rca adapters from ready made. They work with my foxtech 200mw and the readymade anntennas
Jaryd107 is offline Find More Posts by Jaryd107
Old Nov 26, 2012, 07:00 PM
Joined Aug 2008
Thanks!
Sold IBCrazy 5.8Ghz BluBeam set with rp-sma adapters srk.heli FPV Equipment (FS/W) 7 Jun 13, 2012 06:42 PM
Wanted Eagle Eyes GS, 5.8ghz CP antennas, SMA 90*, RP-SMA 90* Adidas4275 FPV Equipment (FS/W) 6 Apr 21, 2012 02:00 AM
Sold Brand New 5.8GHz CP Antennas, RP-SMA healthyfatboy FPV Equipment (FS/W) 4 Mar 28, 2012 10:04 AM
Discussion Foxtech 5.8ghz 200mw FPV Battery Recommendations In SkySurfer? superfly611 FPV Talk 1 Mar 26, 2012 08:56 AM
Sold 5.8ghz rp-sma SPW, CL, 4 turn Helical whakahere FPV Equipment (FS/W) 9 Oct 29, 2011 10:55 AM
