Old Feb 23, 2012, 12:00 AM
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
Help!
Evo 9: Landing mode changes servo positions
I haven't flown in a month or so, and today I powered up my 6 servo glider and Evo 9 to check out the settings. I have flown this plane many times.
Things looked fine in the "normal" flight mode (mode 1). Then I put it into "landing" mode (mode 4), and everything but the rudder changed position. Flaps and elevator came down, ailerons went up. I have crow linked to the throttle stick, and it looked like the throttle stick was half-way down, but it was full up.
The only thing I know that can do this is to have a different trim position set in landing mode. When I look at the trim position for the various controls, it is the same in both normal and landing modes. And anyway, the positions for the controls are far outside what you can set with a trim.
Something has changed since the last time I flew, and I have no idea what it could be. I'm sure I'm using the correct model, I checked that several times.
Help!
BillO is offline Find More Posts by BillO
Old Feb 25, 2012, 09:16 PM
Firecracker!
BillO's Avatar
I noticed that all the six-servo planes had the same problem, so I suspected maybe the throttle stick had gone bad. To test that idea, I assigned the spoiler function to one of the sliders instead of the throttle stick, and presto everything was back to normal!
Guess this radio needs service then...
Old Feb 26, 2012, 09:11 PM
Firecracker!
BillO's Avatar
Anybody want to add something? Similar experience, yea/nay on the diagnosis, whatever...
Discussion Evo 9: Landing mode changes servo position BillO Radios 0 Feb 22, 2012 01:56 PM
Discussion X mode prop positions? ripmax Multirotor Talk 4 Feb 14, 2012 03:29 PM
Discussion DX7 flight mode changes rudder center? eagle777 Beginner Training Area (Heli-Electric) 3 Sep 26, 2011 12:48 PM
For Sale Royal Evo 9 and Royal Evo 7 upgraded to 9 olgol Aircraft - General - Radio Equipment (FS/W) 2 May 04, 2011 02:08 PM
Governor Mode in the Evo 9? aplphabandaid Radios 0 Nov 15, 2004 10:33 AM
