Old Nov 24, 2010, 05:12 AM
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Build Log
New Project Stuart Double 10
Hi All.
Well I suppose it was enevetable after completion of the Stuart V10 and reverse gear !.
I have purchased a full set of old Stuart castings for the Double 10 twin.
I got them for arround half the price Stuart now want and they have the old style forged crankshaft .
I will of course be buying the reversing gear kit to fit to the engine later in the build As I have not gone completely mad yet !
Good job I reduilt my lathe
Dunc2504
dunc2504 is offline Find More Posts by dunc2504
Old Nov 25, 2010, 05:28 PM
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Decided to make a mess of my lathe and mill and start on the engine
I machined up the box support on the mill for the bottom and on the lathe for the top(just wanted to try out my new faceplate )
Next up was the engine base . This was milled flat on the bottom, turned over and the crank bearing hold downs milled flat and level.
Next up I used a bull nosed cutter to open up the slots for the bearing blocks to sit in
Finally the standard mounting points were milled flat and level.
Next up will be the tedious removal of casting flash with needle files
Lucky for me there is not too much , and I do want the castings to look nice prior to painting
More when I get round to it .
Dunc2504
Old Dec 01, 2010, 04:55 PM
Malmo City Hvc, Sweden
Joined Apr 2004
Nice work Dunc!
I'm building the D10 aswell, also with the reversing set. Just finnished soldering up the a new crankshaft for it, you should really wait with the crankshaft, o make sure every other dimension is correct, wich in my case the soleplate was to small, so after mounting the standards they sat to close to each other making the crankshaft too big to fit properly.
Here's the new cranksgaft
Iccccie is offline Find More Posts by Iccccie
Old Dec 01, 2010, 05:44 PM
tel47's Avatar
Bathurst District, NSW, Australia
Joined Nov 2010
The D10 is a nice engine, I'm in the throes of doing one the hard way - fabricated from barstock!
tel47 is offline Find More Posts by tel47
Old Dec 01, 2010, 06:34 PM
The Sicilian Texan
ironman1's Avatar
USA, TX, Waco
Joined Mar 2010
re: Build Log New Project Stuart Double 10
Dunc2504 is that a X1 Micro Mill you are using? Does it mill smooth just using a drill chuck? Good start. Keep us posted. ironman1
ironman1 is offline Find More Posts by ironman1
Old Dec 01, 2010, 06:51 PM
Rainhill UK
Joined Sep 2007
How are you finding the X1 milling the castings I have used mine with brass and some ally and had no problems at all but have never seriousley tried castings but I will soon as I have a nice water pump comming.
have you thought of a belt drive conversion it makes it a lot smother.
by the way you make it look to easy.
Peter
HS93 is offline Find More Posts by HS93
Old Dec 01, 2010, 08:17 PM
South Texas
Joined Jul 2003
I have a sneaking suspicion that for Dunc it IS easy!
Reg Hinnant is offline Find More Posts by Reg Hinnant
Old Dec 01, 2010, 11:28 PM
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Hi.
I use a collet chuck mostly for milling , but have found that as long as you tighten the chuck correctly and make shallow cuts , there is no problems on cast iron.
In fact with a sharp cutter it cuts better than brass.
You need to remember to lock up the verticle slide adjuster first though.
I had to use the chuck for the bull nosed cutter as I have lost my 10 mm collet (another is on order )
Thanks for the crankshaft tip , I will measure the soleplate and standards prior to cutting.
Dunc2504
Old Dec 02, 2010, 04:29 AM
Rainhill UK
Joined Sep 2007
thank you for that , ill be trying soon on a vertical 3" water pump and yes over collets I have two draws full of small toolingcutters colletstipsetc and can never find or find I have bought and imperial cutter and have no collet butyou thought you had a full set so it's order some more only to find it a week later just after the new one arives
Peter
Old Dec 03, 2010, 12:26 AM
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
That sounds about right Peter.
Re the d10 crankshaft , I will take measurements from the soulplate and centre the journals of the crankshaft to the plate.
But mine is an old casting set and appears perfectly matched to the drawings.
Did you make yours to the drawing spec size?
Dunc2504
Old Dec 08, 2010, 05:50 PM
Joined Apr 2004
Had a test run on compressed air today!
Stuart D10 steam engine test (1 min 7 sec)
Old Dec 09, 2010, 02:10 AM
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Nice.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Dec 13, 2010, 04:51 AM
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Hi All.
Just got back from two weeks repair work in Tallinn
Never been so cold for so long !
Anyhow ! did some more work on the double 10 today .
Turned up the tops and faced the bases of the standards, and bored the bore for the crossheads.
I am on my last trip prior to Xmas next week , so I am going to take my files and finish off the boxbed, soulplate and standards in the evenings(with a nice glass of red )
I want to get rid of any remaining casting flash prior to fitting up , hole drilling and painting of these parts.
More later.
Dunc2504
Old Dec 13, 2010, 11:14 AM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Nice work, Duncan!
Kmot is offline Find More Posts by Kmot
Old Dec 13, 2010, 11:22 PM
MILLERTIME's Avatar
Joined Apr 2004
Nice lathe work.
Build Log Stuart 10 V Build dunc2504 Steam Boats 26 Dec 05, 2010 02:59 PM
Discussion Help with OS Max 10 - few questions for project m1tch Engines 6 Nov 11, 2010 09:04 PM
Discussion New A-10 project pacro Foamy EDFs 8 Dec 18, 2006 03:00 PM
