Old Feb 17, 2013, 03:46 PM
Joined Jan 2013
3- blade
What is a good rule for using a 3 blade instead of 2 blade prop? What will be the affect on plane speed, pulling power, etc?Does a 3 blade affect a 2 stroke different than a 4 stroke? All input will be considered.
mashp39 is offline Find More Posts by mashp39
Old Feb 17, 2013, 05:05 PM
Staffs, UK
Joined Nov 2003
From 2-blade prop reduce diameter by 10% and leave pitch the same. E.g. 10x6 to 9x6 3-blade.
Performance will then be very similar. Slightly less thrust from 3-blade, pitch speed about the same.
Steve
slipstick is online now Find More Posts by slipstick
Old Feb 17, 2013, 05:41 PM
Zor
Ontario,Canada
Joined Feb 2007
mashp39,
Slipstick is giving you good advice but it is not easy to find prop 10% smaller in diameter.
5 x .9 = 4.5
6 x .9 = 5.4
7 x .9 = 6.3
8 x .9 = 7.2
9 x .9 = 8.1
10 x .9 = 9.0
11 x .9 = 9.9
12 x .9 = 10.8
13 x .9 = 11.7
14 x .9 = 12.6
15 x .9 = 13.5
16 x .9 = 14.4
17 x .9 = 15.3
18 x .9 = 16.2
19 x .9 = 17.1
20 x .9 = 18.0
We have to select a diamiter available on the market.
A rule of thumb is to reduce the diameter and/or pitch or both by 1/2" for the smaller props and by 1" for the larger props.
A three blade is often selected to improve ground clearance.
Note that the prop does not know if the engine is a 2 strokes or a 4 strokes.
Also 4 stroke engnes are limited to lower RPMs and will use larger diameter props.
Zor
Zor is offline Find More Posts by Zor
Last edited by Zor; Feb 17, 2013 at 06:41 PM. Reason: correcting typos where noticed.
Reply With Quote  (Disabled)
Old Feb 17, 2013, 09:14 PM
United States, CO, Dacono
Joined Nov 2010
Great chart Zor, thanks a bunch!
cherokeenut is offline Find More Posts by cherokeenut
Old Feb 18, 2013, 03:19 PM
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
Typically the plane will slow some but thrust or lift will increase.
scootrb4 is offline Find More Posts by scootrb4
Old Feb 18, 2013, 04:06 PM
Staffs, UK
Joined Nov 2003
Usually the opposite. You need to use a smaller diameter so the prop disc is smaller and the 3-blade is slightly less efficient than 2 blades. The net result is LESS thrust.
Steve
Old Feb 18, 2013, 09:59 PM
scootrb4's Avatar
Joined Nov 2011
Steve
Going by these prop charts for a Cobra motor I had purchased. I see what I though I experienced in flight.
Example 11x8x2 = 1740g thrust
11x7x3 =1886g while pulling the same 377 watts as the 11x8
But speed dropped considerably
Of course if you dropped down in diameter the thrust # would drop
Looks like there is a lot more to prop selection than a rule of thumb, I'm just learning....
Old Feb 19, 2013, 03:13 AM
Staffs, UK
Joined Nov 2003
Interesting chart but note that the two props you're talking about are completely different makes and types of prop. Plus we're in the fuel section....unfortunately IC motors don't react in the same way as electric motors to different loadings.
OTOH I haven't tested the theory very often so it's always possible there are exceptions. Maybe if the original prop was too small for the motor you could use a 3-blade the same diameter and end up with a better match .
Steve
Old Feb 19, 2013, 09:10 AM
scootrb4's Avatar
Joined Nov 2011
Steve
I understand, & yeah, I have never seen a chart like that for a gas engine.
Old Feb 19, 2013, 09:33 AM
Jesus Freak
AtTheCross's Avatar
Southern CA
Joined Oct 2008
So if my model was using a 3 blade 12x6 could I just use a 2 blade 12x6?
AtTheCross is offline Find More Posts by AtTheCross
Old Feb 19, 2013, 10:33 AM
United States, NM, Holloman AFB
Joined Oct 2007
Yes and no. You could use a 12x6 2 blade IF your engine has extra available RPM's to give you. Otherwise you need to increase either pitch diameter or both to put the same amount of load on the engine. eg. 12x6x3 turning 16,000 could mean 12x6x2 turning 17,500. So you could possibly grenade your engine if it unloads too much.
F16DCC is offline Find More Posts by F16DCC
Old Feb 19, 2013, 07:45 PM
Zor
Ontario,Canada
Joined Feb 2007
Yes, a rule of thumb is only a starting point.
I have to assume that the chart is showing values measured in a static test without any forward speeds.
It means that most of the blades are stalled and the values not realistic.
Also like slipstick mentioned the different manufacturer is likely to have a differnt blade shape as well as a different airfoil of the blades.
Still the chart can be useful to some modelers but it does not reflect the in flight performance.
Zor
For Sale Scale 3 blade prop with adjustable pitch blades! unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 4 Apr 03, 2013 09:51 AM
For Sale Scale 3 blade prop with adjustable pitch blades! unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Feb 02, 2013 10:49 AM
Sold 3 electric props for sale (brand new) Parkzone, GWS 3 blade and 2 blade aquaanox Aircraft - Electric - Power Systems (FS/W) 3 Jan 31, 2013 10:36 PM
Discussion Tips for swapping out fan 5 blade to 3 blade heli3d Micro EDF Jets and Power Systems 1 Jan 23, 2013 09:25 PM
Sold Blade 3-n-1 control unit - BLH3501 - new in package. Fits Blade MCPX heli skyking1 Aircraft - Electric - Helis (FS/W) 0 Jan 20, 2013 09:28 AM
