Old Feb 07, 2013, 01:31 AM
Prescott Valley, AZ
Joined Dec 2008
Mach None twin
So I have this idea to build a Mach None converted to electric. I know this has been done. I will use a 2212-06 with an apc 6x4 on 3 cells. But then I got thinking why not build a two fuselage style twin with stretched wing and tail. I think I'll call it the Double O' Nothing. Any body out there interested in seeing what will happen? Any suggestions are appreciated.
GROUND BOUND is offline Find More Posts by GROUND BOUND
Old Feb 07, 2013, 10:12 AM
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Definitely interested in seeing what will happen.
Suggest sorting out the expensive bit placement and attendant wiring issues well before applying the covering/painting the finished model
Am always amazed we've not seen more multis since e-power got loose. It just about takes away the 'suddenly it became assymetric' problem of oily multis.
Good luck with the project
Dereck
Dereck is offline Find More Posts by Dereck
Old Feb 07, 2013, 02:40 PM
Prescott Valley, AZ
Joined Dec 2008
Thanks for the advice. I'm going with foam core wings and built up fuse. Thinking of 2 1300 mah 3s batts. Also going to install rudders and make it a taildragger. Keep the suggestions and encouragement coming. Don't want this one to 'die on the vine' so to speak.
Old Feb 08, 2013, 09:36 AM
Joined Jan 2009
Mach bagel, mach nicht bagel. Sorry, I couldn't resist. Sometimes these thread titles send my mind scurrying down strange corridors.
rafe_b is offline Find More Posts by rafe_b
Old Feb 08, 2013, 01:38 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Don't forget the differential throttle with a twin. Now a true 'cartwheel' is something single motor models can only dream about
eflightray is offline Find More Posts by eflightray
Old Feb 08, 2013, 09:46 PM
Prescott Valley, AZ
Joined Dec 2008
Can you give some more detail about setting up differential throttle? It sounds like fun!
Old Feb 09, 2013, 07:37 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
There are a few threads regarding differential throttle, basically it is mixing a twins throttles with rudder -
Differential throttle-steering on an elec. twin
The Twins: multi purpose cargo plane scroll down to post #116.
There are other references as well. Have fun
Addition: I use it on my Sunderland for better water steering, but some twin fliers have used it in flight.
Old Feb 10, 2013, 09:33 PM
Prescott Valley, AZ
Joined Dec 2008
Thanks Eflightray,
I did some reading and I think I'll try the V-tail mixer as I have one.
Wanted Mach 1 and Mach None kits gavoss Aircraft - Fuel - Airplanes (FS/W) 2 Apr 17, 2010 12:41 PM
Ace Mach None marfish 1/2A Planes 33 Aug 23, 2008 08:53 AM
Sold Mach None Kit by ACE RC NIB Jim Blanchfield Aircraft - Fuel - Airplanes (FS/W) 3 Mar 15, 2008 12:24 PM
Wanted Ace Mach None dankar04 Aircraft - Fuel - Airplanes (FS/W) 2 Nov 30, 2007 10:43 AM
ACE Mach None jzanutto 1/2A Planes 2 Jun 01, 2005 12:35 PM
