Old Jan 28, 2013, 07:12 PM
Joined Dec 2012
Gallery
Two-cylinder steam engine design
163413fc is offline Find More Posts by 163413fc
Old Jan 28, 2013, 07:36 PM
Ariel WA
Joined Apr 2005
Looks like two singles hooked up front to back. Think about flipping one around and designing a cylinder block with bores spaced just far enough apart to get a center bearing on the crank shaft. then put the valve chests on each end. Use one displacement oiler and manifold the two steam supplies to the valve chests.
Would look more like a 2 cylinder engine than 2 singles.
Dave
Phoneman2005 is offline Find More Posts by Phoneman2005
Old Jan 28, 2013, 07:43 PM
Shanghai'd Expat
herrmill's Avatar
Xiaoshan, China
Joined Jun 2006
Very nice work. Again, I will need to stop by your shop next time I am down in Foshan.
herrmill is offline Find More Posts by herrmill
Old Jan 28, 2013, 08:56 PM
Just call me "Mo"
mogogear's Avatar
NE PDX OR
Joined Aug 2008
Nice ! As opposed to aesthetics on the a different arrangement- as it stands now the ability to not be self starting would be the biggest concern to me. If they were 90 degrees off they would be more reliable in self starting as well as running smoother.
And yes flipped around and have valve casing facing out would look more traditional - but Saito and Aster ( made by Saito perhaps) did have this arrangement on their 2 and 3 cylinder engines. The linkage should be able to flip around in your CAD program so the reversing gear stays simple like you have it and be controlled by one lever.
I also like the inclusion of a driven water pump. Nice touch
To combine exhaust, intake manifolds and only have one lubricator would be more cost effective for you as well as a cleaner look.
Keep up the work!!
mogogear is offline Find More Posts by mogogear
Old Jan 30, 2013, 11:42 AM
Canada, ON, Toronto
Joined Jan 2013
Those look like 2 PM Research engines linked?
SteamSurge is offline Find More Posts by SteamSurge
Old Feb 01, 2013, 12:42 AM
Just call me "Mo"
mogogear's Avatar
NE PDX OR
Joined Aug 2008
Somewhat, more classically Stuart in support style- with the valve chest in line instead as opposed
Discussion Live Steam 1920 Steam Yacht Ocean Steam model on EBay Reg Hinnant Steam Boats 2 Jan 23, 2013 08:56 AM
For Sale Twin Cylinder Steam Engine for boat 163413fc Boats (FS/W) 0 Dec 27, 2012 10:23 PM
Sold Complete Small Single Cylinder Steam Engine Set Up $95.00 FREE SHIPPED!!! stevster Boats (FS/W) 5 Dec 15, 2012 12:20 PM
Wanted Wanted: 2 or 3 Cylinder Saito Steam Engine stevster Boats (FS/W) 0 Nov 30, 2011 12:38 PM
