Old Apr 05, 2014, 07:14 PM
United States, MO, Stockton
Joined Oct 2013
Cool
hate to admit it
Yeah I hate to admit it, but the weather has calmed down and the sun has started to shine, and I'm able to fly again. the conversions I did this winter are doing well and give me flight times around 9 to 15 minutes, the other great thing is the convienence of flying , no gas or glow plug or support equipment, plane battery, and transmitter, and they fly with power, in fact I did touch n go's and the las one the plane left the ground again no prob, but then the battery ran out and I coasted it back down, this is from a hard core engine guy, my big guys are still gas, but I'll probably fly more electric
so I say thanks to you guys who helped, I'm looking forward to my next adventure which will be foam construction sam
slam555 is offline Find More Posts by slam555
Old Apr 05, 2014, 08:10 PM
USA, VA, Arlington
Joined Jul 2002
Congratulations, I hope you enjoy the e-side. Couple of tips that cost me dearly to learn. First be sure to set up your transmitter FAIL SAFE to zero throttle. Once my 100" ws Piper Cub landed and I turned off my TX before I shutdown the plane. The TX had a legacy Failsafe setting of 100% throttle and within second the motor went ballistic and the plane launched itself into the pits. No injuries but no more monster Cub and lots of funny looks. Second, don't run lithium power batteries below 50% and certainly not to the cutoff point. Use your Watt Meter to measure battery condition after short duration flights and log the settings until you ease closer to 50% remaining lipo life. Then fly with your TX timer running and don't quibble when it says LAND. Yes it may mean investing in more lipo's so you can fly just as much but your batteries will live longer and you will never risk puffy packs or fires from over stressing the lithium. Look into safety switches too. I like the ones Atlanta Hobby sells. My foamies are too light to allow using safety switches and I'm always nervous when I plug in the flight packs that power the RX and the motor/prop. Its like having a live bomb. With a safety switch you can get everything ready up to the Clear Prop moment without arming the Motor/prop. Then you insert the safety switch to arm the power train and go fly. When you land the safety switch is the first thing I remove. Once it is out the "bomb" is neutralized.
LaxLife is offline Find More Posts by LaxLife
Old Apr 05, 2014, 08:38 PM
I eat glue
Canada, NS, Yarmouth
Joined Jul 2006
Welcome to the "bright" side! I've got a few 1/4 WWI plans that I'll be building from, and all electric. Electric doesn't have to mean small. With the price of offshore lipos, you can have a 10s pack for just over 100.00 bucks. Fly the big one, put it on the charger and fly the smaller ones while the biggie is recharging.
baldguy is online now Find More Posts by baldguy
Old Apr 05, 2014, 10:37 PM
Joined Oct 2013
hate to admit it
thanks for the info guys, I'm interested in that safety switch, my sporster has no battery hatch, I load the battery through the wing area and then the wing, so I plug the battery in and then mount the wing, It doesn't take long, but the plane is alive with the safety switch it sound like there's no power til I want, goota goo slam
Old Apr 06, 2014, 09:14 AM
USA, VA, Arlington
Joined Jul 2002
Here are Atlanta Hobby's offerings in Arming Switches.
http://www.atlantahobby.com/Store/pc...idCategory=700
You can make your own too as long as the port on the fuselage is solidly mounted as you'll want a definite connection when arming not fumbling with a loose fuselage port (done that). I power all my receivers independent of the motor (no BEC's on my ESC). This allows me to fiddle with servos, retracts and check trims without dealing with a live prop.
Don't forget that FAILSAFE setting: throttle to ZERO at signal loss.
Old Apr 06, 2014, 09:29 AM
USA, VA, Arlington
Joined Jul 2002
Big scale e-conversions often have balancing issues to get the CG right. I HATE to add lead weights! I usually end up using the wing hatch to access the batteries. Tensions would run way too high for me to think clearly if I had to work with a live, fully connected 5000 mAh 12s battery while I fiddled with the wing mounting, checked the CG and all the other pre-flight chores. The other alternative would be to take the prop off and mount it at the end but who wants to mount a big carbon prop to a live motor? If there is a spinner involved its just too much of a hassle.
Discussion Coordinated Turns - I Hate to Admit Being Wrong Leo L Electric Warbirds 10 Oct 28, 2013 12:36 PM
Discussion They'll never admit their crimes..but History will judge MtnGoat Life, The Universe, and Politics 2 Sep 25, 2013 09:54 PM
Discussion Well, I guess I admit defeat. Steve_ Beginner Training Area (Heli-Electric) 8 Sep 24, 2013 08:31 AM
Discussion Hate hate hate POWERGROOVES Life, The Universe, and Politics 57 Feb 20, 2010 03:09 AM
