Old Jan 25, 2014, 06:37 PM
Germany
Joined Sep 2009
Hobbywing 2-6S Platinum-30A-Pro OPTO for 6S hex or a different ESC?
Hey,
I want to get these motors:
SUNNYSKY X4108S 380KV
and these ESC:
I want to flash them with BLHeli.
Would you recommend those and the 30A or shoud I get different ESC for my 6S FY680 setup?
CyberCrash is offline Find More Posts by CyberCrash
Old Jan 25, 2014, 07:15 PM
VA
Joined Nov 2009
The only thing I can say about them is I have used Hobbywing platinum 2-6s rated esc on 6s (80A) and they worked without any problems. Factory firmware though which wasn't as responsive as the new firmware. I hoped to pick up one of the Pentium versions for simonk experimenting but neither local LHS had any.
pug398 is offline Find More Posts by pug398
Old Mar 09, 2014, 01:34 PM
Joined Jan 2014
I am having trouble right now with this ESC. Only one though. Can't get it to "see" throttle.
Gr8ful Flyer is offline Find More Posts by Gr8ful Flyer
Old Mar 24, 2014, 01:37 AM
United States, CA, Citrus Heights
Joined Jun 2013
Hi CyberCrash did you find the optimum ESCs for those sunnyskies?
artemen is online now Find More Posts by artemen
Old Mar 24, 2014, 04:18 AM
Germany
Joined Sep 2009
HI artemen,
still no copter on my side, except for everything else... ;-)
It seems there are much better motors available. Better bearings, thicker axis. Looks better. And can handle 13" props on 6S with very high efficiency.
I guess I will order this set:
http://www.hobby-wing.com/arris-m680...per-combo.html
Features a quality frame, the new motors + 13" props.
(You still get the FY680 super combo with the Arris 4010 (need to write them a comment during your order)
I wouldn't go for the SunnySky any more!!!
But go for the Hobby-Wing Platinum Pro 30A. They can be flashed with BLHeli and seems to work perfectly on 6s and high pole count motors.
Old Apr 25, 2014, 02:57 AM
Hochiminh City
Joined Mar 2004
I used this esc with BLheli reflash on my tarot T810 with tarot 4114 -400KV motor prop 15x55 and the load is 5D Mark II with gimbal (1.7kg for gimbal). and I got over 80 flight without any problem.
caotri is offline Find More Posts by caotri
Old Apr 25, 2014, 04:05 AM
Germany
Joined Sep 2009
Thank you so much for your feedback.
>Did you notice any difference in power or stability after flashing?
Old Apr 28, 2014, 08:49 AM
Joined Jan 2014
i have a problem programming Esc ; I using the lcd programming box via pc see pictures do i have to set parameters on the speed calculator for SunnySky X4108S 380kV
and vhat sudd i do there . Can some help me out here and do it looks ok according to the prictur ore ?? using 6s battery 22,2 v
I use this motors on tarot 690
Maxpower50 is offline Find More Posts by Maxpower50
Question Hobbywing 2-6S Platinum 30A-Pro OPTO ESC = Tmotor 30A OPTO PRO ESC? Captain3D Multirotor Electronics 25 Jul 22, 2014 03:30 PM
Discussion Hobbywing platinum 30a 6s esc config UgashikBob Multirotor Electronics 2 Jan 02, 2014 11:23 PM
Wanted Hobbywing Opto Platinum Pro 150a esc v8truckin Aircraft - Electric - Power Systems (FS/W) 0 Nov 20, 2013 11:16 AM
Discussion Hobbywing Platinum 30A Opto ESC xtian3188 Multirotor Power Systems 1 Nov 01, 2013 10:12 AM
For Sale Hobbywing platinum pro 150A opto esc **reduced** postalflyer72 Aircraft - Electric - Power Systems (FS/W) 1 Jul 09, 2011 02:14 AM
