Closed Thread
Old Jul 05, 2012, 01:32 PM
soarin' dude
sailplanator's Avatar
Buenos Aires
Joined Jun 2009
Question
Brushless for this model?
Hi there folks!
I decided to go brushless and, since it will be my first attempt, I need some of your kind advice.
This is a 3m glider loosely based on M. Drela's Bubble Dancer (the wings are S3021, the outer panels come from a deceased Dynaflite DayDream, and the rest is scratch built). The whole thing is around 1300g, well beyond the 850g of the original BD but it flies nicely.
I'd like to know the specs of the motor, battery, ESC and propeller, for nose mount or power pod.
Thanks a lot!!!
sailplanator is offline Find More Posts by sailplanator
Old Jul 06, 2012, 06:43 AM
South Africa, GP, Kempton Park
Joined Sep 2009
Suggestion
Hi
I am in the planning stages of fitting out an AVA Pro E that is on the way. Cost is an issue to me and most of the high end motors are very expensive. The next concern was the inside diameter of the nose and lastly the total mass of the model.
For the above reasons I have decided to try the Hyperion GS2218-10.
It is light, compact and will deliver up to about 550watt in an emergency. It might not give me vertical climb but all I need to do is reach about 200m altitude in about 25 seconds.
Hope this helps.
Kaptein is offline Find More Posts by Kaptein
Old Jul 06, 2012, 07:47 AM
soarin' dude
Buenos Aires
Joined Jun 2009
sure, thanks! I don't need vertical climb neither. Not even the 25sec mark. Just want to put it higher than my highstart does!
Old Jul 06, 2012, 09:56 AM
Dragons, Windmills. All Same.
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
Hi,
No need for a rocket ship.
For casual flying, about 50watts per pound or about 150-200watts total for your sailplane will be just fine.
If you run a 3s at 20 amps, or 2s at 27amp, you will be fine.
For prop something around 10/8 to 12/6 max, as a guess.
Several free online caculators to help with your prop, motor and batteries.
Jared
jcstalls is online now Find More Posts by jcstalls
Old Jul 06, 2012, 11:59 AM
jcstalls's Avatar
Joined May 2002
Here are a couple for you;
http://www.brantuas.com/ezcalc/dma1.asp
http://www.ecalc.ch/motorcalc_e.htm
Enjoy ~
Old Jul 07, 2012, 06:37 AM
soarin' dude
Buenos Aires
Joined Jun 2009
thanks a lot, Jared! awesome!
Old Jul 07, 2012, 08:33 AM
soarin' dude
Buenos Aires
Joined Jun 2009
I think this will do the job:
http://www.focalprice.com/YO099X/A22..._Airplane.html
Old Jul 07, 2012, 12:58 PM
jcstalls's Avatar
Joined May 2002
Could be.
Unless you are in a rush, take your time. You will learn much and make a better decision, the first time.
I would also be considering how I would mount the motor.
Easy option is to cut off the nose, slap a bulkhead on and mount it. Ulgy, yet works.
More work yet nicer option would be to cut nose, in a way to mount the motor and build up around it along with flaring with the spinner, around the motor and the fuse. Lots of theads here on RCG.
Jared
Old Jul 07, 2012, 04:14 PM
soarin' dude
Buenos Aires
Joined Jun 2009
sure, I'm a total newbie, I'm still reading all that I can and learning how the whole thing works, not only the motor, also the batteries and ESC. until now, never before heard of kv, C's, etc...
anyway, I own a couple of gliders, the one pictured is the biggest. Should I fall short, it will be useful for the smaller ones.
Closed Thread
Help! Can You Identify this model???? Jcopter Foamies (Kits) 1 Jun 24, 2012 08:57 PM
Discussion What model is this??? edsuarez Sailplane Talk 1 Jun 19, 2012 10:42 AM
Discussion What is best DF for "this model" ? Cr@sh Electric Ducted Fan Jet Talk 0 Mar 26, 2012 12:31 AM
Question Will a enya .40 6002 do for this model? gonzalito Beginner Training Area (Fuel) 13 Mar 12, 2012 02:26 PM
Brushless options for this model StahlmanGC Scale Kit/Scratch Built 3 Oct 22, 2004 03:47 PM
