Old Oct 30, 2001, 07:34 PM
SKINNI MINI flyer
Barrett's Avatar
Pearl River, LA, USA
Joined Sep 2001
Is there a way to remove epoxy? Please help!
After a repair to my tiger moth tonight, I pulled it out after the 5 minute epoxy had dried and i was putting the prop back on and noticed that the gear box would not spin all the way around because i got some epoxy in the teeth on the gear. Is there a way to get this out? It is dry. But will mineral spirits or nail polish remover work ? Or anything? Please help! Thanks!
Barrett is offline Find More Posts by Barrett
Old Oct 30, 2001, 08:12 PM
Master of disaster
Travis's Avatar
Northern Virginia
Joined May 2000
You may be able to losen the epoxy by soaking the parts in
rubbing alcohol, mayby.
epoxy that cures on plastic can be carefully and slowly chipped
and peeled away. This is tedious and it sucks.
Don't use anything that could harm the plastic gears or housing.
Given the time and tribulation it would take to remove the epoxy
you may be happier buying a new gearbox!
Travis is offline Find More Posts by Travis
Old Oct 30, 2001, 08:49 PM
Steve Diebolt's Avatar
Torrance, CA, USA
Joined Jan 2001
If alcohol doesn't work, try regular household vinegar. Vinegar will take epoxy off Monokote type covering and may work well on your problem also.
Regards,
Steve
Steve Diebolt is offline Find More Posts by Steve Diebolt
Old Oct 30, 2001, 08:59 PM
Oak Harbor, Washington, United States
Joined Jan 2001
Heat will usually soften and allow epoxy to be peeled away. The question is whether or not the epoxy will soften before the heat damages the gear. I guess you might try it as a last resort. I've used a heat gun for doing this where I've removed epoxy from an airframe.
Norm
Norm is offline Find More Posts by Norm
Old Oct 30, 2001, 10:01 PM
SKINNI MINI flyer
Barrett's Avatar
Joined Sep 2001
Well thanks for all the quick replies guys! I have good news! I got the epoxy out of the gearbox about an hour ago. I dont know if the fact that i put some paint thinner and nail polish remover on it helped, but after playing with it for a while it became loose and i used a tooth pick to push it out. Then i had about a 20 min flight right in the back yard at 9:30 at night! thanks again!
Old Oct 30, 2001, 11:14 PM
Member
Northwest Territory
Joined Jan 2001
I am glad to see you got the epoxy off the gear. For future reference, in addition to the suggestions above, you might try freezing. Some epoxies become very brittle and can easily be chipped off.
Lee
El Pe is offline Find More Posts by El Pe
Old Oct 31, 2001, 12:30 PM
SKINNI MINI flyer
Barrett's Avatar
Joined Sep 2001
thanks again
Thanks guys! More successful flying done this morning!
Help! epoxy (PLEASE HELP) tacticdude Foamies (Scratchbuilt) 12 Jun 19, 2007 03:54 PM
best way to remove epoxy from fiberglass gel coat? JoeR Composites Fabrication 3 Feb 09, 2005 09:29 PM
is there a way to fix feigao broken wires please help new flyer Power Systems 0 Feb 03, 2005 03:05 PM
What's the easiest way? Please help!!!! Shane Sizemore Foamies (Kits) 1 Mar 04, 2004 04:28 PM
Question Hornet tail drive shaft gives way, please help. yapjy Micro Helis 4 Jun 14, 2003 10:24 PM
