Old Mar 29, 2011, 11:10 PM
stikmunkeyrc's Avatar
Melbourne, Australia
Joined Apr 2009
Framing in Solidworks
Hi all Solidworks users,
What is the best/quickest way to go from 3D model to framing for laser cutting and construction
Let say from the attached photo to this http://www.rcgroups.com/forums/attac...mentid=2985148
stikmunkeyrc is offline Find More Posts by stikmunkeyrc
Old Apr 06, 2011, 09:21 AM
Joined Jul 2008
I'm not an solidworks guru, not an engineer(learned basics by my self, so i may be totally wrong), so in first model I've done it in these steps:
1) created reference plane, where i wanted balsa part to appear
2) used sketch->intersection curve to get initial curve to work with and then manually added missing details, like interlocking, holes for stringers, etc.
3) extruded sketch that I've got in step 2 to desired wood thickness.
It's a lot of manual work, especially if you do a lot of interlocking, but i could not find a better way.
From other side, if you choose clever reference planes and use clever helping construction lines, it's not that hard.
I've tried another approach, like make a loft of a part and then make part like
in picture attached and then subtracted it from initial loft, but as long as final result must go to laser cutting, it looked to me not very suitable.
dziedrius is offline Find More Posts by dziedrius
Old Apr 10, 2011, 08:48 PM
United States, TX, Rockwall
Joined Jun 2007
Well, you need the 3D solidworks part to start with?
Available?
bob
limeybob is offline Find More Posts by limeybob
Old Apr 10, 2011, 08:50 PM
Joined Jun 2007
This thread will help\http://www.rcscalebuilder.com/forum/...TID=12332&PN=1
bob
Help! Sweep problem in Solidworks Edu_ns CAD/CAM 8 Jan 12, 2011 03:01 PM
Discussion Voltij in SolidWorks Marcelo Blumm Slope 5 Dec 15, 2010 08:57 PM
Discussion Help with "fillet" in Solidworks stikmunkeyrc CAD/CAM 8 Oct 22, 2010 06:53 AM
Lofting in Solidworks troyhm The Builders Workshop 3 Nov 13, 2005 01:48 PM
Question Loft elliptical wing in SolidWorks erazz The Builders Workshop 3 Jul 09, 2004 12:14 AM
